Old 14-10-08, 12:16 PM   #1
Jase22
Default Radial master cylinders from Thailand on ebay
Would you?
I think they look pretty smart, and are clearly just copies of Brembo's, but would you risk it? Tough call I think, as your master cylinder is basically just a piston to push oil to your calipers, so there's not much to go wrong.
I'll open this one up to debate, some of the main cons will likely be:
- made from monkey metal
- replacement parts (lack of)
For reference:
http://cgi.ebay.co.uk/Yamaha-CBR-GSX...d=p3286.c0.m14
Old 14-10-08, 12:18 PM   #2
Default Re: Radial master cylinders from Thailand on ebay
I would also argue the small point that it's a part which will kill you if it goes wrong.
I wouldn't. There's nothing wrong with the standard one (on the SV), if for yours, didn't the TT6 have pretty good brakes anyway?
Old 14-10-08, 12:21 PM   #3
Mr Speirs
Mr Speirs's Avatar
Mmmm I would steer clear.
Old 14-10-08, 12:22 PM   #4
Jase22
Yeah there's nothing wrong with the brakes on my bike, I just came across them on ebay and thought I'd open it up for debate.
The only real issue I have is the fact I can't buy nice looking levers for my bike (nobody seems to do fitment), but that's just a tarty thing!
Old 14-10-08, 12:24 PM   #5
Woz
Originally Posted by Jonathan Foreigner on Ebay
BRAKE RADIAL MASTER CYLINDER FOR SINGLE BRAKE ONLY!!!
Does that mean single disc? If so, useless!
Old 14-10-08, 12:29 PM   #6
Mr Speirs
Mr Speirs's Avatar
Jeeeez just went and had a look and even on a picture they look poorly made.
Old 14-10-08, 12:31 PM   #7
Jase22
Having just browsed a few of the other auctions, some are single caliper some are for both, like this one
http://cgi.ebay.co.uk/GSX-R-CBR-S4-H...d=p3286.c0.m14
Old 14-10-08, 02:28 PM   #8
muffles
I suppose the single brake one is just due to the MC size? Although I don't recognise those banjo bolts, mind you I'm not exactly an expert. I thought the banjos might have been the reason why it would only work on a single caliper, but that's rubbish as well. I could only think it would be the size of the cylinder...
Old 14-10-08, 02:36 PM   #9
Grinch
Tell you what, you buy on and then tell us what you think...
Old 14-10-08, 03:20 PM   #10
Wouldn't touch it with yours Not all of the thai stuff is automatically counterfeit or terrible, but this stuff is. At least they've stopped claiming it's genuine, there's been loads of accounts banned over stuff like this.
Some of the counterfeits are interesting- not in this case, but with small carbon fibre parts, loads of it is outsourced to china and thailand (most obvious in mountain biking) because they have the best mass-production for-hire facilities for carbon fibre. Often the counterfeits are actually identical to the real thing, made in the same factory!I read about one case where a company designed carbon fibre brake levers, and the counterfeits were on ebay before they'd even received their own first delivery of the genuine ones
Identify these master cylinders! TOLAROS SV Talk, Tuning & Tweaking 8 06-02-09 03:54 PM
master cylinders naked vs faired. Razor SV Talk, Tuning & Tweaking 14 15-04-08 01:25 PM
Radial Master Cylinder? squirrel_hunter Bikes - Talk & Issues 4 28-07-07 10:17 PM
Rear brake master cylinders? svrash SV Talk, Tuning & Tweaking 2 16-10-06 11:04 PM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
