Old 19-10-08, 02:53 PM   #1
Default wurth dry chain lube (again)
we had this debate about which chain lube is best recently, well ive been using this wurth dry stuff for a while now and my chain is rattling and sounding like theres no lube on it at all? i dont like the sound tbh and am thinking of changing back to pj1 which i used to use, anyone else had this?
Old 19-10-08, 02:56 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: wurth dry chain lube (again)
Nope its been fine on the chain on Liz's Duke.
How often are you applying the lube to it ?
Old 19-10-08, 02:56 PM   #3
Lozzo
The words 'dry' and 'lube' don't go together, simple as that. Get a Scottoiler on it and just clean it more often if that sort of thing floats your particular boat. A properly set up oiler doesn't create much mess anyway.
Old 19-10-08, 02:57 PM   #4
well because of it sounding dry i'm sticking loads on.
Old 19-10-08, 02:59 PM   #5
fizzwheel
fizzwheel's Avatar
I found it goes on better if you lube it after a run. I.e when the chains warm.
Knowing you this is a daft question, but what sort of state is your chain in, i.e is it nice and clean ?
Old 19-10-08, 03:02 PM   #6
oh yes! its clean.
Old 19-10-08, 03:07 PM   #7
fizzwheel
fizzwheel's Avatar
Don't know then. If you're not happy with it, then change for something else.
Old 19-10-08, 03:09 PM   #8
i like the clean ness off the dry stuff so aslong as its doing its job i'll keep using it.
Old 19-10-08, 03:22 PM   #9
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
the "lube" is only there to keep the o-rings alive, not to lubricate the chain and sprockets, that's all behind the o-rings...
if the chain isn't stretching or generally binding then it's doing it's job, if it sounds dry that's because it is, the clue is in the "dry lube" bit
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 19-10-08, 03:34 PM   #10
the best my rear wheel has ever run was when i soaked my chain in car engine oil, it virtually ran friction free! this was noticeable alot upon riding the bike but it did fling everywhere as expected! it seemed to clean the chain well too, i might try that again.
How much lube? (Chain lube!) AndyL SV Talk, Tuning & Tweaking 10 10-01-09 08:04 PM
Wurth dry chain lube.. what? Draper Bikes - Talk & Issues 54 29-05-08 09:59 AM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Wurth chain lube Dave The Rave Bikes - Talk & Issues 10 15-11-07 05:32 PM
Wurth chain lube Dave The Rave Bikes - Talk & Issues 3 14-11-07 03:50 PM
