Old 21-10-08, 11:39 AM   #1
Cam_73
Question SV OEM Chain
I am assuming it's of the Endless species?
Spun the wheel last night, can't see any of the rivets with the tell tale indents to signify a soft link.
In that case when taking it off, avoiding the "remove swingarm" scenario is it okay to chop it with a grinder?
Have had JT sprokets and Tsubaki Gold X-ring sitting in the house for a few weeks now. I feel shame at my lack of progress.
Any advice appreciated folks.
Old 21-10-08, 11:44 AM   #2
Default Re: SV OEM Chain
Yes it's endless. Yes you take swingarm out to get it off, which isn't a bad idea as there's no grease in there as standard.
Fine to lob it off with grinder if not though.
Old 21-10-08, 11:50 AM   #3
Yeah, fine to just amputate it. Though tbh taking the swingarm off and greasing all the gubbins would be a good idea anyway, they never have enough grease in from the factory and the bearings are expensive
Old 21-10-08, 12:53 PM   #4
vardypeeps
Sounds like mine has suffered from the non grease from factory thing. Swing arm bearings are shot so good idea to do it that way.
Old 21-10-08, 01:55 PM   #5
Dangerous Dave
Quick and easy method is cut it with an angle grinder, but as mentioned before and depending on your mechanical skills removing the swingarm has it benefits as well.
Old 21-10-08, 03:27 PM   #6
Spokey
can you get the swing arm bolt out without the special tool ?
Would be a good job done to remove it and give it some grease anyway
nANA
Old 21-10-08, 03:34 PM   #7
You can use a punch. Not really the professional way but can be done in an emergency.
Proper way to bodge it is to grind a socket to fit the castellations, I think I used a 32mm or was it 1 1/4AF? I can't remember but something about that.
Old 21-10-08, 03:43 PM   #8
davepreston
subject related queston
my chain has about 3 inches play ( i think i could use it as a skipping rope ) ive been told i need a new chain and sprocket. i am on a budget so what are the best to get without spending a fortune and from where, cheers for any help
p.s make the answers idiot proof i am irish
Old 21-10-08, 03:48 PM   #9
JT sprockets, tsubaki chain from BandCexpress. If you buy cheap crap then you'll just be replacing it again shortly.
Old 21-10-08, 03:50 PM   #10
davepreston
cheers going to look them up now
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Cam Chain jambo Stuff Wanted 6 05-08-08 10:28 AM
Chain on the way out? krhall SV Talk, Tuning & Tweaking 5 20-04-08 07:14 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
