View Poll Results: Ride or walk it?
Ride 10 45.45%
Walk it 12 54.55%
Voters: 22. You may not vote on this poll
Old 27-10-08, 05:50 PM   #1
Stu
Trinity
Stu's Avatar
Default Ramp
Quick question. Got to get my bike up 2 steps, I've got a short plank. Should I ride it up the plank (feet won't be able to reach floor) or walk beside it using engine power to get it up steps.
N.B. have to go through a door at the top of the steps.
Old 27-10-08, 05:53 PM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: Ramp
Walk it.
Old 27-10-08, 05:53 PM   #3
Default Re: Ramp
How much space is there to get through door? If you can walk alongside bike easy enough then do so.
Personally, if I was doing that a lot, I'd build a wider ramp so I could put feet down if needs be.
Old 27-10-08, 06:07 PM   #4
Stu
Trinity
Stu's Avatar
Default Re: Ramp
Doubt there's enough room to walk it. It's a normal house sized door.
Just a one off hopefully (electric gate has broken at work)
Old 27-10-08, 06:07 PM   #5
Stu
Trinity
Stu's Avatar
Default Re: Ramp
Ah, but there's more planks available - I think that's the answer - Thanks!
Old 27-10-08, 06:21 PM   #6
Dangerous Dave
Default Re: Ramp
Walk it, use the engine to go up the ramp and you to support the bike.
Old 27-10-08, 06:25 PM   #7
jimmy__riddle
Default Re: Ramp
i have to use a ramp everytime i use my bike, made one as wide as possible and just ride it up. much easier than walking IMO
Old 27-10-08, 06:28 PM   #8
jaffacakes
Default Re: Ramp
walk it using engine power, then when you get to the top step, throw your leg over carfully and ride it through the door. Hope you don't drop it
Old 27-10-08, 06:36 PM   #9
Lozzo
Default Re: Ramp
Leave it outside.
Old 27-10-08, 06:59 PM   #10
muffles
Default Re: Ramp
I'd be careful to make sure the ramp is long enough - I tried this one to get a bike through a (house size) door - and I figured I would ride it up the ramp and the problem was when the front wheel was on the ramp and the rear wheel was still on the ground, my feet couldn't reach the floor very easily. Very nearly went over.
I had to stop because the door was quite tight (as I'd expect with most bike/house door combos). If you can keep riding it should be fine.
