Old 28-10-08, 01:39 AM   #1
sv_rory
Default Any computer wizards?
i would like to connect my pc to my television instead of using the monitor.
how do i do this?
Old 28-10-08, 01:46 AM   #2
Harry Mowtown
Default Re: Any computer wizards?
Depends on what TV you have.
Do you have a modern LCD TV? If you do, it should be pretty simple. Its usually one lead.
Old 28-10-08, 02:05 AM   #3
ThEGr33k
Some modern Graphics cards have HDMI outputs and all modern LCD/plasma TV's have HDMI input, if both of those are present on yours then its good with that.
If not then all Computers have analogue output (VGA blue socket, if not they come with an adaptor to change DVI to VGA) again most modern flat screens have this input... As simple as fitting a normal monitor.
Hope this helps and isnt too confusing
Old 28-10-08, 08:15 AM   #4
wyrdness
We had a good thread about this a few days ago. It's worth a look, rather than repeat all of the advice here.
http://forums.sv650.org/showthread.php?t=119591
In brief, use a DVI to HDMI converter if your PC and TV have those, otherwise VGA.
Old 28-10-08, 08:53 AM   #5
Dave20046
Dave20046's Avatar
how do i do this?
most tv's won't be upto it if you actually want to read text.
Otherwise get an 's-video cable' and link 'em up
Old 28-10-08, 08:55 AM   #6
AndyL
Take pictures of the output connectors on your graphics card (back of PC) and also take pictures of the input connectors on your TV, even better if you can also post the make and model of the TV and graphics card. Then I can advise you.
Old 28-10-08, 09:53 AM   #7
wyrdness
All modern flat panel TVs will be up to it.
Old 28-10-08, 01:24 PM   #8
Dave20046
Dave20046's Avatar
sorry didn't read the flash tv bit!
Old 05-11-08, 01:30 AM   #9
sv_rory
the television i am using is a sony 28 inch jobbie, its not a tft or lcd or plasma. its just a general television with a scart and aerial output on the back. as for the computer i am not sure exactly what output i require for the cable to plug into. please could somebody point me in the right direction
Old 05-11-08, 01:32 AM   #10
sv_rory
sorry i would need to monitor to work aswell as the tv so i can either switch between the two or have them on at the same time preferably
Computer help please Stu Idle Banter 7 09-11-08 07:28 PM
computer help!! malks Idle Banter 13 21-10-08 08:02 PM
Computer help 600+ Idle Banter 16 16-07-08 09:40 AM
computer help again? kwak zzr Idle Banter 36 18-06-07 07:24 PM
Any wireless wizards out there? Belkin router help needed Well Oiled Idle Banter 12 18-03-06 12:42 PM
