Old 28-10-08, 10:06 AM   #1
Paul the 6th
Paul the 6th's Avatar
Default K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt?
As title really, if anyone knows, could they please let me know.
Oh and you get extra bonus points if you could let me know where I can get hold of the bolt & nut from if it does need one (which I think it does)
Thanks in advance!
Old 28-10-08, 10:18 AM   #2
Lozzo
Default Re: K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt?
Yes, you will need the bolt and a locking nut as I think the SV one is too short.
Your local Suzuki dealer will be able to supply one. Dont use any old bolt, it's important you get the correct grade and shouldered length. Put the bolt in from right to left, with the nut on the sidestand side of the bike.
Old 28-10-08, 10:20 AM   #3
simesb
But you won't have time to do it as you're finishing the second Catherine Wheel video. Man Up Paul!!!
Old 28-10-08, 10:21 AM   #4
Paul the 6th
finishing moving house lol
cheers lozzo, will give padgetts or someone a ring - I don't like using them but I don't know where else to call locally
Old 28-10-08, 11:11 AM   #5
Dangerous Dave
Search for the part number here, and order the part here (takes 2-4 days).
Old 28-10-08, 11:22 AM   #6
Anyone know what the best way to manuevre the battery tray around is?
On mine I ended up with the undertray lowered 10mm for the SRAD shock to fit ... and the battery raised up with the tray cut out to fit the ZX6R shock... So I'm no stranger to such bodgings, but I haven't done this particular swap before.
Old 28-10-08, 12:14 PM   #7
sv650k4
on the pointy i moved my hole battery box/tray back about an inch and it let the gsxr shock fit in a treat.and you dont have a lump out of the battery box bit nor the bottom of the seat 2 give the battery space.
Old 28-10-08, 12:27 PM   #8
Paul the 6th
robinsons foundry didn't have them in stock = 2-4 days
went with spares direct who've got them in stock, delivered tomorrow for 6 quid. Not bad... Any tools I need to bring with me yc? I'm scared. Is everything gonna be alright?
Old 28-10-08, 01:29 PM   #9
BillyC
BillyC's Avatar
Yes; and you'll need a big torque wrench... If I recall, it needs to be torqued to something like 90 or 100 nm.
Old 28-10-08, 01:37 PM   #10
Lozzo
Originally Posted by BillyC View Post
Yes; and you'll need a big torque wrench... If I recall, it needs to be torqued to something like 2 grunts and a fart.
Post corrected for you.
rear shock bolt GSXR pencil shavings SV Talk, Tuning & Tweaking 4 25-04-09 04:26 PM
Shock Lower Mounting Bolt (For Pointy 650) Bez Stuff Wanted 0 28-10-07 02:36 PM
GSXR Shock For Pointy Bez For Sale - SV's and SV related items 5 03-09-07 09:44 PM
Pointy seat, subframe and gsxr shock ianofbhills For Sale - SV's and SV related items 12 13-08-07 05:07 AM
nuts & bolt for GSXR shock chris SVK3 SV Talk, Tuning & Tweaking 1 12-01-05 10:51 PM
