Old 30-10-08, 09:34 PM   #1
Phaelok
Default Misfire?
I rode my bike this morning - warmed it up fully and off i went as usual.
Going through country side around 40mph, my engine had a flatspot mid revs and low revs when changed up a gear, when i pulled on the throttle, it felt as if it was running out of petrol (and theres loads in there as i filled up) and just bogging down.
Coming to the next village, i slowed down and dropped a cog, let the clutch out and there was backfiring!
My thoughts on this?
Misfire perhaps?
Now my bike has been serviced a month ago by JHS racing who are apparently Sv650 specialists. Fine and dandy.
But what i want to know is, what are the possible causes? And are JHS liable to repair them? If its misfire due to a faulty HT lead or spark plug, surely JHS should have spotted this?
Im absolutely enraged, as i paid £600 for a major 15k service, and a MONTH later... THIS SHOULD NOT BE HAPPENING!
Any help and advice appreciated.
Old 30-10-08, 09:36 PM   #2
Dangerous Dave
Default Re: Misfire?
Was it raining, or the roads wet?
Old 30-10-08, 09:39 PM   #3
Phaelok
Roads dry this morning dave - i know of the spark plug issue getting soaked.
I ride a 1999 SV650SX, and the only thing ive done recently is taken the battery out to charge it. It could be terminals methinks?
I read another posting on here - but my tacho doesnt appear to be doing anything wierd, or i dont think it has. Ill check when i next ride tomorrow morning. My terminals are securely screwed on, and the cap put on the positive.
Other than that i dont know what it could be??
Spark plugs and fuel air mix is what i was going along the lines of - but dont know.
Old 31-10-08, 01:57 PM   #4
DeeHawk
My 99ey has been doing kinda the same thing for a while now.
Especially the "drowning" thing when adding throttle after driving in low or med rev for a little while.
My idea is that the carbs are unsynchronized, or the needles (Dyno Jet kit) need replacement. I don't hope it's the latter. I plan to work out the problem before spring time.
Old 31-10-08, 02:07 PM   #5
Biker Biggles
Biker Biggles's Avatar
Carb icing?
Damp cold weather at the moment so if it cures itself as soon as you stop and let some warmth around the carbs that could be it.
Old 01-11-08, 09:43 AM   #6
Phaelok
I made sure it wasnt the carbs icing - i took my bike out for a good 30min ride this morning in freezing cold weather...
No hiccups from the engine at all. I wonder what it could have been?
I hope james over at JHS manages to find something as im going to london tonight!
Old 01-11-08, 08:04 PM   #7
vardypeeps
As you said higher up you have checked the plugs but that's the only thing I could guide you towards.
low rev misfire?? ricky SV Talk, Tuning & Tweaking 6 25-09-08 06:19 PM
Misfire donscarecrow SV Talk, Tuning & Tweaking 4 25-08-08 09:48 PM
Still Got A Misfire SAMMY650 SV Talk, Tuning & Tweaking 8 08-10-07 07:34 PM
Misfire perhaps? Larry SV Talk, Tuning & Tweaking 2 02-09-07 10:31 PM
MISFIRE DAX SV Talk, Tuning & Tweaking 5 18-05-06 10:19 AM
