Old 04-11-08, 11:28 AM   #1
tonybmw92
Default Weired Problem
Had to ride bike under the strand underpass this morning in central london and on the way back up the slope whilst giving it a bit of welly my bike coughed and spluttered and then became very slow and had lack of power. im wondering if this is a water issue as it chucked it down on the way home lastnight. this has happened to me last week after going down a hill. when i got back on the level it ran a bit spluttery?.
Any ideas?.Ive recently had oil issues and found that to be a little bit of ouil had found its way into the airbox and after a good clean it was fine.
Old 04-11-08, 11:31 AM   #2
AndyBrad
Default Re: Weired Problem
50p on water in the plug.
Old 04-11-08, 11:57 AM   #3
Nobbylad
Nobbylad's Avatar
Wouldn't the 50p fall off whilst riding though? especially if he's giving it welly?
Old 04-11-08, 12:01 PM   #4
tonybmw92
ok i will have to see how it runs when i start her up when i go home tonight. should i get some of the magic spray from maplins or just replace the cap?.
Old 04-11-08, 12:04 PM   #5
Little bit of WD40 up the drain hole to clear the moisture for the moment. Can send you some silicon grease no problem when i get some baggies.
Old 04-11-08, 12:28 PM   #6
Dangerous Dave
+ 1, then when you get home take the front plug cap off and ensure everything is nice a dry down there and smear some grease on it and whack it back in.
Have you got a Fender Extender, they can help?
Old 04-11-08, 12:49 PM   #7
tonybmw92
what smear some grease on the top of the plug or inside the cap? sorry to be so non techie chaps.
Old 04-11-08, 12:50 PM   #8
Around the rubber ridged thing on the top of the cap so it makes a seal with the head
Old 04-11-08, 12:52 PM   #9
Dangerous Dave
+ 1
Sorry, my fault as I should have written that in the first place.
Old 04-11-08, 01:22 PM   #10
tonybmw92
cheers guys i will give it a go.
There seems to be a problem... gettin2dizzy Idle Banter 10 28-04-08 10:51 PM
Weired Biker Wave -- what does it mean ? SpankyHam Bikes - Talk & Issues 21 09-08-06 08:20 AM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
