Old 04-11-08, 07:59 PM   #1
shelleyamy
Default Longer Clutch Cable
Trying to finish the last couple of jobs on my Curvy/GSXR K7 front end conversion.
Just put on my new TL1000 clip-ons (feel a bit high) and the clutch and brake lines are now a bit tight.
I will be fittiing braided brake lines ,so not a problem, but when doing tight right turns the cable tightens and i lose drive.
So my queston is, can anyone recomend a slightly longer cable?
Thanks
Mike
Old 04-11-08, 08:03 PM   #2
Dangerous Dave
Default Re: Longer Clutch Cable
Is the clutch cable routed properly, I have never known there to be a problem. If it is really an issue then a 'N' model clutch cable will fit and is slightly longer.
Old 04-11-08, 08:13 PM   #3
shelleyamy
I think so, i took photos of all the cable routings before i started and have put them back the same way. Saying that it may not of been right to start with, so i will re check tomorow.
Thanks
Mike
Old 04-11-08, 08:15 PM   #4
Sean_C
Originally Posted by shelleyamy View Post
<snip> Saying that it may not of been right to start with, so i will re check tomorow.
Thanks
Mike
That's probably the culprit. Didn't have to change my cable, nor the routing of it.
Old 04-11-08, 08:19 PM   #5
shelleyamy
Sean
Was your's the slightly longer naked cable?
Mike
Old 04-11-08, 08:23 PM   #6
Sean_C
Nope. My bike was S model, standard clutch cable.
It's naked now because I tried jumping a ditch
Old 04-11-08, 08:24 PM   #7
Dangerous Dave
TL clip-ons on a GSXR front end aren't really noticeable higher than OEM SV.
Old 04-11-08, 08:31 PM   #8
shelleyamy
I rode it for a couple of days with the GSXR bars, (minus the bodywork,as they hit) which are very low, so the change to the TL bars feel a lot higher, almost upright.
Mike
Old 04-11-08, 08:34 PM   #9
Dangerous Dave
Mike
Yes but that is comparing GSXR to TL, trust me there is hardly a difference in the bar height from SV to TL so the clutch cables length shouldn't be an issue.
Old 04-11-08, 08:38 PM   #10
shelleyamy
Yeah, i am expecting to re route tomorow and cure the problem.
Mike
clutch cable DoubleD Stuff Wanted 1 01-05-08 11:17 PM
clutch and throttle cable joronsen SV Talk, Tuning & Tweaking 3 14-02-08 09:08 AM
Clutch Cable replacement. dmracing SV Talk, Tuning & Tweaking 1 21-10-07 11:45 AM
Clutch cable 21QUEST For Sale - SV's and SV related items 1 03-04-06 12:03 AM
longer throttle cable? ben650 SV Talk, Tuning & Tweaking 2 01-02-06 07:30 PM
