Old 13-11-08, 03:46 PM   #1
AndyBrad
Default Rear brake notchiness
when i press the brake all is good until it gets to the full extent of the leaver travel and it starts to get notchy.
poss master cly needing a rebuild? or something else?
Old 13-11-08, 04:12 PM   #2
Baph
Default Re: Rear brake notchiness
WD40 & grease up the pivot point on the brake pedal.
That should sort you out. Also, check to ensure that the spring is still attached to the pedal - mine has gone missing & occsionally feels like this - but it's not enough of a problem for me to pay the £3 or whatever it is for the tiny spring.
zx600r rear 'break' question, (rear brake). steve.s Bikes - Talk & Issues 6 19-02-09 07:50 PM
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Brake light not working when rear brake is used.. StreetHawk SV Talk, Tuning & Tweaking 10 16-04-07 03:40 AM
