Old 14-11-08, 11:06 AM   #1
neio79
Default Recommend me a good Bike to bike radio for Autocom
Right good peeps of the Org. Next year I am off on a cracking trip with a bunch of good mates. One of them is getting an Autocom set up like mine. Mine is a Pro 7 sport model. A few years old but still full Vox and radio connectivity on it.
Therefore I am after a good recommendation for a set of good PMR’s (personal mobile radios) for use with auto com giving good bike to bike comms. I don’t want to spend more than £100 for 2 if I can help it.
So please recommend away.
Old 14-11-08, 11:14 AM   #2
Luckypants
Luckypants's Avatar
Default Re: Recommend me a good Bike to bike radio for Autocom
one that fits the lead from the autocom unit.
I have a motorola one.
HTH
Old 14-11-08, 11:15 AM   #3
timwilky
timwilky's Avatar
Personally I would suggest you look at some of the import radios that also work on the PMR 446 frequencies with a bit more umph.
PMR has such a poor range
Not Grumpy, opinionated.
Old 14-11-08, 11:33 AM   #4
DanAbnormal
Any good to you?
File Type: jpg lexibook--barbie-first-walkie-talkie.jpg (21.4 KB, 0 views)
Old 14-11-08, 11:41 AM   #5
neio79
thanks. will look into them any ideas wherethey can be bought?
Originally Posted by DanAbnormal View Post
Any good to you?
no i dont like pink
Old 14-11-08, 01:22 PM   #6
Grinch
I have PMR446 Multicom Junior raido's at home, you can pick up all the local testering going past our street. Nice little raido's but not sure if you can get hold of them any more.
Old 14-11-08, 02:03 PM   #7
neio79
Been looking around and the ones Autocom recomend for the Po 7 are the Kenwood, Motorola T5622 and icom F25SR.
The Motorola can be got for £80 for 2 and all i then need is the lead from Autocom for £13.
i think i have a winner. The range is up to 3K which should be ok as i dont see us being more than a mile appart.
Old 14-11-08, 10:17 PM   #8
Kilted Ginger
that's up to 3k direct line of sight, fine if yoiare going across the salt plains but in built up areas of undulating terrain it is significantly reduced. The pmr's are limeted to 5w I think hence the limited range, think it's to prevent interference with other authorized transmitters. Think there are "penalties" if you get caught using the stronger ones but don't know what they are or if they apply to Europe. Hope this helps
Old 19-11-08, 11:55 PM   #9
mbuk
I use Midland G7s with autocom, good robust radio around £75 for the pair.
added bonus is .....there is an easy mod to up the power from 0.5 watts to 3 watts just by desoldering a jumper on the circuit board.
Not that I would do that , Let me know if you want instructions.
Mike
Old 20-11-08, 11:22 AM   #10
Jelster
I use the 5watt version of Kenwoods PMR radio. Works very well.
Radio to go with Autocom L3nny Bikes - Talk & Issues 16 06-03-09 05:02 PM
bike radio sv_rory Idle Banter 16 10-01-09 03:43 PM
Bike covers, recommend me a good one for outdoors. Razor Bikes - Talk & Issues 9 29-08-07 03:14 AM
Bike to Bike radio bargains................ independentphoto Bikes - Talk & Issues 10 02-02-06 12:16 PM
Fitting an autocom thingy on the bike... valleyboy SV Talk, Tuning & Tweaking 3 15-07-05 08:31 AM
