Old 15-11-08, 06:40 AM   #1
vzzzbuxt
Default would a pointy front end fit into a curvy?
as in pointy yokes and stem and forks?
looking at a cheap- short term repair option to get it on the road sraight away.
cheers?
Old 15-11-08, 07:12 AM   #2
zadar
Default Re: would a pointy front end fit into a curvy?
yes and no.not direct bolt on but can be made to work.
stem would need bearing swap,same as for gsxr forks.or fit curvy stem in pointy yokes.or use curvy yokes if good.
fender mount points are different so you would need fender.
and you need new spacer to use curvy wheel.
Pointy K3 Front End svdemon For Sale - SV's and SV related items 60 23-06-09 08:02 PM
will a curvy (99-02) FRONT brake lever fit a k3 pointy DarrenSV650S SV Talk, Tuning & Tweaking 2 09-02-09 09:22 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Brake Calipers-suit Curvy or Pointy 21QUEST For Sale - SV's and SV related items 0 07-04-08 11:42 PM
Pointy or Curvy, 650 or 1000 Naked SV Front Master Cylinder SoulKiss Stuff Wanted 0 19-03-08 06:30 PM
