Old 15-11-08, 07:38 PM   #1
arcdef
Default just went to see a bike need advice!
well went to look at an sv650 today looks nice however few things to ask!
1 - there was a small amount of the old mayonnaise around the oil cap, i know this could mean coolant in the oil in a car but is this the same in a bike? however it has been sitting in a cold room for the last 3 weeks and started for short lengths of time and not moved so could this just be condensation build up from the short cold runs?? how can i check if its really bad?
2 - whats the best way to see if the brakes are in good condition as from what i could see its imposible to tell how much of the pads are left?
cheers
Old 15-11-08, 08:44 PM   #2
Default Re: just went to see a bike need advice!!!
1: Look in the coolant. Short runs especially starting it up and not running it (like a total clueless cabbage...) will wet the oil. I doubt there is a problem though, they're not really prone to head gasket issues.
2: Yes you can, look harder Pads are pretty cheap anyway.
Old 15-11-08, 09:03 PM   #3
arcdef
exactly what i wanted to hear!!! where abouts do you check the coolant? it has a belly pan on it which makes it hard to check oil level so i hope coolant isnt down there too!
cheers
Old 15-11-08, 09:06 PM   #4
Is it nekkid or a gay one?
Old 15-11-08, 09:06 PM   #5
arcdef
its a half faired/gay one w reg to be exact
Old 15-11-08, 09:10 PM   #6
oi, less of the gay ok!!!!!
if its been sat in a cold place for a while, sat about and only run on short journeys, IT JUST needs an oil change and a bloody good run. Suzy was sat like that for 6 months when Im Indoors handed her over all those years ago, she had the mayo on the oil cap. Got an oil change gave her a good run and all was fine.... some people always think on the really bad side!
Old 15-11-08, 09:10 PM   #7
and that will be a 2000 S then!
Old 15-11-08, 09:14 PM   #8
arcdef
yeah a 2000 S model it is, i have to say ive fallen in love and more than likely will be buying her!!! just wanted to clear that up! managed to reduce the price too so just want someone bike minded to check it over and ill be parting with my cash!
nervy times!
Old 15-11-08, 10:56 PM   #9
petevtwin650
Re the brakes you should perhaps be more concerned about the condition of the discs. Especially the rear.
How many miles has it done?
Be mindful of the fact that the Sv is favoured by novices so an 8 year old Sv could have had a chequered and hard life.
Old 15-11-08, 11:50 PM   #10
vilguy
provided the engine is sound and theres no damage, most other "wear" items can be sorted relatively cheaply and easily. They are a good bargaining tool too Things like head races are something i would check. They can be expensive to sort at a dealer * as i presume from your lack of experience you wouldnt want to give this a go if it needed them. Takes 10 seconds to check and you can check the wheels bearings whilst your at it.
Other quick one is just to check tyres, they are one of the larger expenses.
NEC Bike Ride Out Advice. mattb200 Bikes - Talk & Issues 1 29-11-08 10:08 PM
Advice on new bike Bunks Bikes - Talk & Issues 22 19-10-08 07:30 PM
New Bike Advice 650SFTT Bikes - Talk & Issues 11 28-06-08 01:02 PM
Mountain Bike advice please.. StreetHawk Idle Banter 18 01-05-08 05:27 PM
Bike advice ... rubberduckofdeath Idle Banter 5 05-06-06 11:03 AM
