Old 18-11-08, 02:42 AM   #1
a1istair
Default SV1000 Starts fine but no drive
Hi
My friend's SV1000 has encountered a problem. It starts fine in neutal, and seems to switch into 1st and 2nd gears but when the clutch is let out nothing happens. The last time he was out (Fri), the clutch lever seemed "a bit different" and the biting point seemed to have shifted slightly. All this has happened suddenly after a 2 day period of non-riding. It seems like the clutch is either jammed on or the plates have stopped working completely. What has happened? How does he fix it?
Thanks for your help,
Alistair.
Old 18-11-08, 07:38 AM   #2
Default Re: SV1000 Starts fine but no drive
It has an hydraulic clutch - well, it did, but I reckon it hasn't got any fluid in it now. Was a problem with some early SV1000s, a revised seal on the slave cylinder, (the bit on the sprocket cover), was fitted, but not all bikes were affected, it's possible that your friends bike has suffered the same.
I'd try refilling the system first, if this solves the problem then look for the leak.
Old 18-11-08, 12:14 PM   #3
Would no fluid in a hydraulic clutch not simply refuse to disengage?
One way to get off a speeding fine! I'm_a_Newbie Idle Banter 20 25-04-07 09:16 PM
Bus lane fine curium Soho Massive 13 09-04-07 07:32 PM
£400 fine with £60 costs Blue_SV650S Idle Banter 13 06-02-07 06:14 PM
Ward8124 down not BB! He is fine! minifun Bikes - Talk & Issues 52 26-09-06 02:49 PM
Another bloody fine Jelster Soho Massive 14 23-11-05 01:51 PM
