Old 21-11-08, 03:55 PM   #1
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Anyone got instructions on how to fit a Scottoiler?
I have one on the bike, it doesn't work. I've never had one before so have no idea how to go about fault finding.
It's an underseat mount not behind the plate, I believe it's suction fed from one of the carb balancing hoses??. And THAT my friends is the extent of my knowledge on the matter (oh, and you put lube in the top too)
TA
How to amuze an idiot:
Look right-> <-Look Left
Old 21-11-08, 03:57 PM   #2
Stig
Default Re: Anyone got instructions on how to fit a Scottoiler?
Go to their website. They have online destructions on how to install them.
Old 21-11-08, 03:58 PM   #3
Stig
http://www.scottoiler.com/support_in...ion-guides.asp
Old 21-11-08, 03:58 PM   #4
Baph
Couldn't be much easier really.
There's 3 pipes coming from the res.
#1: Breather hose, goes to thin air & the end should be higher than the res itself.
#2: Oil feed to chain/sprocket. Obvious.
#3: Suction feed from engine. On newer (v6 onwards I think) this is the black one at the opposite side of the res to the oil feed tube. Follow that to the carbs.
Chances are #3 is the culprit. Or there's air in #2.
Old 21-11-08, 03:58 PM   #5
Stu
Trinity
Stu's Avatar
Yes I have a set thanks very much
What do you mean it doesn't work? No oil at all? is the delivery tube full of oil? otherwise it needs priming.
Could be broken tho'?
Old 21-11-08, 04:07 PM   #6
_Stretchie_
Large Member
Could be fubard BUT
The res is full, nowt is coming out at the chain end HOWEVER I'm pretty sure I can only see one tube connected the the unit itself.
Will get on t'interweb, print the destructions off and if the weather is crappy this weekend, I'll hand them to El Saxo and he can do it while I'm inside and warm....
Old 21-11-08, 04:08 PM   #7
Davies
Originally Posted by BigApe View Post
Cheers for posting that link Simon.......I'm installing mine tomorrow
Old 21-11-08, 04:08 PM   #8
_Stretchie_
Large Member
WHOA...
Everytime Saxo is involved in ANYWAY with a bikes the gearbox stops working, batteries die, bike won't start, something snaps, the bike crashes or he sets fire to it...
I'll do it myself.
Old 21-11-08, 04:11 PM   #9
_Stretchie_
Large Member
Cheers guys, all of you. Have just clicked print and just need to get it done really
TA
Piperecross fitting instructions? oliverchitty SV Talk, Tuning & Tweaking 1 14-05-09 06:26 PM
Hagon Shock Instructions pmapp SV Talk, Tuning & Tweaking 2 10-05-08 07:04 PM
Remus instructions help needed please. Squidders SV Talk, Tuning & Tweaking 12 01-05-08 07:58 PM
Pc3 wireing instructions Davie SV Talk, Tuning & Tweaking 7 02-09-07 10:20 AM
Fitting instructions needed viner SV Talk, Tuning & Tweaking 3 16-06-05 04:11 PM
