Old 01-12-08, 07:40 PM   #1
newts924
Default tail tidy question - sorry.
Sorry to ask, as i think this has been asked loads of times, but i am thinking of getting a tail tidy and wanted to know which one to go for.
I want one which when fitted will pass the MOT without any modification from myself, ie fitting a number plate light. Not to sure if i want to keep the standard indicators or fit mini's, will this matter to which tail tidy?
Are they easy to fit for a novice like myself, by the way i have a k6.
If you have any photos could you post some so i know what they look like fitted.
Thanks and sorry again for asking
Old 01-12-08, 09:28 PM   #2
tosher
Default Re: tail tidy question - sorry.
Bought and fitted the Hamicad . Easy to fit and uses all the original equipment . I think the only MOT issue is the reflector a sticky one does the job I will worry about that when the time comes . There are a couple of gaps around the corner of the undertray when its fitted they are bit annoying but all in all I was pleased with it .
Old 02-12-08, 12:49 PM   #3
Dangerous Dave
Most a MOT friendly as they retain or come with a numberplate light, the only issue is a reflector. I used a small 10p size stick on reflector I got from a bicycle shop, does the trick perfectly.
Old 02-12-08, 01:03 PM   #4
RichT
+1 - bought and fitted a Hamicad. No prob's at all.
Old 02-12-08, 01:34 PM   #5
STRAMASHER
STRAMASHER's Avatar
Hamicad here too. Sorry.
Great finish. Great service. Still mint. I just unscrewed the reflector from the original abomination and stuck it on the bottom of my legal numberplate when its MOT time. It keeps the OE light and you can use the standard winkers.
Sorry.
Old 03-12-08, 09:40 AM   #6
schofs
I also fitted a Hamicad. Main reason I went for it was because of the angle at which it held the number plate - a lot of the others looked too vertical, whereas the Hamicad is much more aligned to the curve of the wheel... if that makes sense!!
Old 03-12-08, 09:59 AM   #7
Lozzo
I have the Hamicad fitted but actually prefer the look of the Evotech one.
On my old K3 naked I had a stainless steel one I picked up cheap off ebay and that was wonderful. Fitted up fine and looked great
Hamicad
Ebay cheapie
Old 03-12-08, 10:38 AM   #8
Amplimator
Heres the evotech one for comparison if its any help....
it looks even better without the number plate light with plate moved up another inch
Amp
Curvy tail skirt or tail tidy mouldy Stuff Wanted 3 21-02-09 12:49 PM
Evotech Tail Tidy Fitted - Question Drew Carey SV Talk, Tuning & Tweaking 20 26-04-08 06:36 PM
Tail Tidy Question. New Leaf Bikes - Talk & Issues 11 11-03-08 09:17 PM
Tail Tidy. Tail Tidy...Sell me your Tail Tidy.... 1world2wheels Stuff Wanted 7 15-07-06 10:09 AM
Undertray/tail tidy question kavana77 SV Talk, Tuning & Tweaking 1 09-09-05 06:53 PM
