Old 06-12-08, 01:34 PM   #1
steveg
steveg's Avatar
Default coolant top up
just checked coolant level, level is at min in reservoir , is it ok to leave at min or should I top up with some distilled water ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 06-12-08, 01:53 PM   #2
Bear
Default Re: coolant top up
Won't do any harm to top up with distilled water. Did you use pre-mixed coolant last time it was filled, or did you mix it yourself? Pre-mix is generally good down to a stupidly low temperature for this country (it's something like a 60/40 mix when you could probably get away with 75/25), so topping it up now and then with distilled water shouldn't do too much harm. What I'd do is alternate distilled water and a mix every other time you top up.
Old 06-12-08, 03:03 PM   #3
steveg
steveg's Avatar
Nice one , it was premix , I put 200 ml of distilled water in but that was too much and was over F line , Fish tank tube to the rescue !
Now just under Full
Cheers Steveg
AKA Papa Smurf
Old 06-12-08, 03:07 PM   #4
On my own bike I don't really bother about coolant level in the expansion tank, so long as there's something in it it be right.
On other peoples bikes I do ensure it's spot on though just in case
Old 06-12-08, 04:17 PM   #5
ricky
never checked my water level in the 7 months i have owned the bike opps
Old 07-12-08, 08:39 AM   #6
Haluk
Is it under the seat?
Old 07-12-08, 10:12 AM   #7
Viney
No! The expansion tank is under the right hand side of the tank, but if you want to check the radiator then you have to take a side pannel off. You will need to remove the seat to lift the tank.
HTH
Old 22-12-08, 01:14 PM   #8
Haluk
Checked my level yesterday, which is on low. How do you get to the coolant bottle to top it up? You don't have to lift the tank for this surely? Sorry I'm being a clueless beginner.
Yes it is pretty difficult to check right level without paddock or centre stand.
Old 22-12-08, 03:17 PM   #9
Yes you do have to lift the tank.
Old 19-01-09, 03:49 PM   #10
branny
I have never checked my coolant (to memory) so thought i should top it up... is the snorkle up the side of the airbox the filler pipe?
Oil in coolant ?! fatneck Bikes - Talk & Issues 16 26-02-08 09:14 PM
Coolant - what to use Flamin_Squirrel Bikes - Talk & Issues 8 22-10-07 03:38 PM
Coolant help therealvw SV Talk, Tuning & Tweaking 3 07-08-07 08:02 PM
coolant leak SimJ SV Talk, Tuning & Tweaking 0 02-05-07 11:05 PM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
