Old 15-12-08, 06:25 PM   #1
steveg
steveg's Avatar
Default red rubber grease
hi
normally use copper grease on back of pads and pin , where can i buy some red rubber grease for piston
would halfords sell it
cheers steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 15-12-08, 06:27 PM   #2
Default Re: red rubber grease
Nope. Ebay mostly, mg owners club.
How much work do you do? Can send you enough to do a bike if you want
Old 15-12-08, 06:32 PM   #3
Dangerous Dave
Google it, there are a few places where you can buy Castrol Red Rubber Grease.
Old 15-12-08, 06:59 PM   #4
steveg
steveg's Avatar
thanks for the offer Chris , I have taken a gander on ebay
there is a 30ml size for 2.80 and a 100g for 4.85
I guess that a little goes a long way so the 30 ml should do me ?
Only clean calipers once a year
Does using the rubber grease stop the caliper from seizing ?
Cheers Steve
AKA Papa Smurf
Old 15-12-08, 07:07 PM   #5
philbut
Should do if you combine that with regular cleaning - i tend just to use a tooth brush and clean brake fluid every few months, particularly in winter - the re-apply grease before you push the pistons back. They'll still need stripping every few years if you ride through winter.
Old 15-12-08, 07:09 PM   #6
Yeah but you still need to strip them properly every now and again, you still get corrosion and unpleasantness behind the seals even if you clean the pistons regularly.
Old 15-12-08, 07:12 PM   #7
Sean_C
For what it's worth, castrol aren't the only people who make red rubber grease. I have a tub of Fuchs red rubber grease.
Old 15-12-08, 07:18 PM   #8
Dangerous Dave
+ 1, RRG isn't a replacement for servicing the brakes.
Aye, yeah sorry my fault but this is what I have always used and tend to call it Castrol.
Old 15-12-08, 07:37 PM   #9
thefallenangel
bought 100g off ebay for £8 delivered.
I imagine a take off and clean 3 times a year (Sep, dec/Jan, April) will be enough and a full strip down every 3 years will keep the calipers going forever.
Old 15-12-08, 07:38 PM   #10
Depending on mileage of course.
Red Rubber Grease Mr Speirs SV Talk, Tuning & Tweaking 15 20-12-08 01:01 AM
Grease - all you could ever want to know ? Spokey SV Talk, Tuning & Tweaking 9 22-10-08 08:01 PM
Castrol Red Rubber Grease. BillyC SV Talk, Tuning & Tweaking 16 18-07-08 11:16 PM
Red Rubber Grease leegriffiths128 SV Talk, Tuning & Tweaking 9 10-04-06 05:51 AM
grease latts650s SV Talk, Tuning & Tweaking 2 24-02-06 07:20 PM
