Old 26-12-08, 02:32 PM   #1
larigos
Default white creamy gunk
I have just replaced the spark plugs and was checking the airbox/filters the main airfilter is a little dirty nothing a little clean wont help. However I took out the metal gause filter on the left hand side and it had a creamy white gunk on the bottom of it - am I to be worried by this? first thing that came to mind was oil/water mix? not sure what would cause this. I have a little white smoke out the rear but only when reving the engine. The oil level is on /just below the full line when on the padock stand. Any ideas??
its a k3 pointy n with 8K on the clock oil change about 500 miles ago, ridden in all weathers rain etc.
Mark
Old 26-12-08, 02:47 PM   #2
Dave20046
Dave20046's Avatar
Default Re: white creamy gunk
Could it be white grease?
Old 26-12-08, 03:13 PM   #3
glade
glade's Avatar
do you do lots of short journeys?
I get white cream/ condensation in my oil sight glass at this time of year because I commute daily 10 miles.
A good long ride and thrashing generally clears it.
glade is offline   Reply With Quote
Old 26-12-08, 03:36 PM   #4
I wouldn't be too worried, condensation and oil vapour get mixed a lot around that area.
Old 26-12-08, 04:12 PM   #5
larigos
cheers, I now have a slight problem - the bolt that hold the rad to the engine has sheered off - I think age etc has softened it etc how do I get it out? I do have a replacement.
Old 26-12-08, 04:19 PM   #6
Dave20046
Dave20046's Avatar
Can you get to any of it? Mole grips?
If not it might be a case of drill out and tapping.
Old 27-12-08, 01:04 PM   #7
Dangerous Dave
New thread started; http://forums.sv650.org/showthread.php?t=123063
Creamy Oil In Sightglass - Can I ride it ??? SV-net SV Talk, Tuning & Tweaking 14 29-12-07 10:43 PM
What's happened to Gunk? ejohnh SV Talk, Tuning & Tweaking 13 15-12-07 09:30 AM
Autosol alternative.... gunk?? Al_Sweetman Bikes - Talk & Issues 13 19-09-07 08:27 PM
green gunk grecian9 Bikes - Talk & Issues 3 29-08-06 08:25 PM
oil filler cap gunk russg SV Talk, Tuning & Tweaking 4 16-02-06 11:48 PM
