Old 28-12-08, 07:11 PM   #1
Shellywoozle
Shellywoozle's Avatar
Default Scottoiler not working
Don't know what I am doing with it, but all I know is I have a dry chain and a full Scottoiler which is on setting no 3.
Mmmmm from that I take it is isn't working LOL.
Kwak had to come and lubricate me, not good as now I have a dirty back end
Any constructive (unrude bike related) help !
Old 28-12-08, 07:24 PM   #2
zsv650
Default Re: Scottoiler not working
is there a kink in the pipe's or blockage you can see.
Old 28-12-08, 07:24 PM   #3
Shellywoozle
No kink in the pipe that I can see
It was empty so I filled it up then it just stopped working, not sure how long it not been working for, must have worked to become empty ! Mmm
CAn you move me into the bike ralk section Mods, I fink I posted in wrong section !!!
Sorri!
Old 28-12-08, 07:27 PM   #4
zsv650
without having a look at it it's hard to think what could be wrong pic's of the offending scotoiler may work.
Old 28-12-08, 07:32 PM   #5
MrMessy
Try putting it on the prime setting. I have had the same problem when they have run out of oil, they do not want to flow again for some reason?
MrMessy is offline   Reply With Quote
Old 28-12-08, 07:46 PM   #6
jaffacakes
Yip, run if on fulll blast. When it is empy, and you go to fill it up, you need to 'bleed' the pipes to get the air out of it.
Old 28-12-08, 07:53 PM   #7
Shellywoozle
Thank you all, will go try the prime setting then, whatever that may be. Cheers all
Old 28-12-08, 07:57 PM   #8
i aint got a freekin clue how those things work! u got lubed up for today anyhow, hows your cold hands woozle?
Old 28-12-08, 08:10 PM   #9
Shellywoozle
Warm now, altho I nearly fainted after my bath, was that hot and think my body went into shock. Got in bath then shower then bed, fell asleep !
Mmmm I feel like p00 but enjoyed the ride thanks mate !
Old 28-12-08, 08:13 PM   #10
no problem'o i always here.
Key not working wilky007 SV Talk, Tuning & Tweaking 12 29-12-08 01:27 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
not working Again! wtdafk SV Talk, Tuning & Tweaking 18 10-01-07 05:29 PM
Scottoiler has stopped working?? MarkyBoy SV Talk, Tuning & Tweaking 8 03-10-06 12:43 PM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
