hey all,
I've got an 52 plate svs and its getting a bit corroded etc So just about to change bolts etc from probolt and thought I would upgrade the brake lines as well as the fittings are corroded. what are the best ones to get?? |
HEL or Goodridge have always worked well for me. Though to be honest any steel braided lines will feel better. Athough that's arguably more down to fresh fluid.
what kinda set up do I need - how many lines etc
(yes i realise i could look at my bike or manual but being lazy!) |
I always go for the race setup: Two lines from the master cylinder, one to each caliper. Not sure if you can get any other setup with aftermarket lines tbh.
Are you doing the rear too? (I wouldn't bother unless you want it for the looks) |
Go for braided lines with a race set-up (two lines) and stainless banjo bolts.
The benefit of braided lines isn't really much, they last longer and don't bulge like rubber lines do when the age. Last edited by Dangerous Dave; 02-01-09 at 06:48 PM. Reason: Rear Brake Line Pictures |
http://www.mandp.co.uk/productinfo.a...s&tier3url=Hel
Clear coating with stainless fittings. Make your job easier and get some speed bleed nipples too. Might have to get them from Demon tweaks though. |
#7 | |
yea i was goin to do the rear as well as its horribly corroded |
quick but silly q but how much longer do braided last compared to rubber lines (i.e service manual says 4 years to replace do they last longer or not?)
#9 |
4 years to replace brake lines. I'd never heard that before and never know anyone do it before either. I suppose braided lines would last longer as the braiding stops the rubber from expanding against the pressure of the system.
#10 |
Braided will last longer, the braiding prevents the rubber hose from swelling and deforming. Rubber hoses have a service limit, they need replaying after a certain amount of years, as do Braided lines but they last more than twice as long (I have a set of eight year old braided lines fitted to a SV).
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads | sv-racing-parts | SV Talk, Tuning & Tweaking | 42 | 15-09-11 10:27 PM |
Brake LInes | vardypeeps | SV Talk, Tuning & Tweaking | 6 | 02-10-08 04:38 PM |
HEL Brake Lines | buckstone | SV Talk, Tuning & Tweaking | 1 | 20-05-08 04:24 AM |
HEL brake lines | streetos | SV Talk, Tuning & Tweaking | 4 | 31-03-05 09:51 PM |
Brake lines | Barty_b0y | SV Talk, Tuning & Tweaking | 4 | 24-02-05 05:32 PM |
