Old 03-01-09, 09:28 PM   #1
AndyL
Default How much lube? (Chain lube!)
Ok, so carrying on from my other thread, I have adjusted my chain tension and cleaned the chain to day using parafin. Tomorrow I will be lubing the chain with Castrol chain lube. I have read through previous threads and if I have understood correctly then it is best to apply the chain lube to the top side of the bottom part of the chain and then push the bike forwards a bit and repeat on the next section of the chain until the entire chain is lubed? (is this correct?). The part I am unsure about is how much chain lube should be applied to each section? Does anyone have a photo of a correctly lubed chain?
Andy
Old 03-01-09, 09:34 PM   #2
Default Re: How much lube? (Chain lube!)
Just get it all so it's a bit wet with lube, just needs a coating. Doesn't need to be absoltely dripping in it. (not an exact science!)
Old 03-01-09, 11:02 PM   #3
skyline
What I do for chain lubing is...
- Get bike on paddock stand to save pushing the bike forward to get to different parts of the chain
- Hold a rag to bottom section of chain and spray the chain section with lube
- Use the rag to wipe the lube into the chain and get the lube into all the nooks and crannies
- Go to next section of chain until done!
Doing it this way tends to clean the chain as well as lube (well a lot of muck comes off anyway) but I still use paraffin on the chain every so often. It also helps minimize fling too.
HTH
Old 05-01-09, 05:22 PM   #4
Steve_God
Steve_God's Avatar
Keep doing it till it's all a bit moist...
(ooo errr!)
SV650s; K6; Metallic Euclase Silver; Fully Faired; Renegade Twin Exhaust Full System (Stubbied); Full ECU Remap; Fabri Tinted DB Screen; Hamicad Fender Eliminater; Bagster Seat/Suzuki Gel Seat; Fenda Extenda; HEL Braided Brake Hoses; R&G Crash Bungs; GSXR Front-end, Triumph Daytona 675 Front Brake Master Cylinder; RedFox Rear Hugger; BMC F.1 Air Filter; Top Box!
Coastal Tours:Great Britain (for Cancer Research) - 3588.2 miles: Completed July 2007. Ireland - 1466 miles: Completed for July 2008
Steve_God is offline   Reply With Quote
Old 05-01-09, 06:22 PM   #5
Alpinestarhero
See Also: Don't lubricate your chain like alpinestarhero. Its not bad for the chain, but it makes a right bloody mess
Old 10-01-09, 01:08 PM   #6
AndyL
Ok so I have only just managed to get around to lubing the chain and Im wondering if I have done it correctly i.e. the correct amount? Also should it look the colour that it does?
I used Castrol chain wax from Halfords.
Old 10-01-09, 02:29 PM   #7
the only thing that puts me off that stuff is its white appearance, thats why i use that wurth dry stuff.
Old 10-01-09, 02:33 PM   #8
looks like chainwax to me. Just plaster your chain with it, it'll only fling off what it don't need anyway. Plus , its better applied to a warm chain. What I usually do is clean the chain go out for a quick spin, then apply what ever lube is on hand. It miht sizzle a bit, but it sticks better and don't fling as much
But then I may just be odd
Old 10-01-09, 03:09 PM   #9
AndyL
I find that it lets a novice like myself easily see where I have actually lubricated
Old 10-01-09, 03:33 PM   #10
u can with any lube, you'll see it go on and look wet just the wurth stuff seems to dry up in a few seconds.
How often do you lube the chain? Binky SV Talk, Tuning & Tweaking 27 11-08-08 03:56 PM
Chain lube. furrybean Ancillaries 17 02-11-07 06:33 PM
Chain Lube jonhunt Bikes - Talk & Issues 7 15-04-07 09:38 PM
Chain Lube fred_dillon SV Talk, Tuning & Tweaking 12 25-05-05 08:30 PM
Chain Lube splke Ancillaries 11 28-10-04 09:22 AM
