I have a K8 with the sensor just near the cutting area for adding an after market can.
I also have the already cut pipework from a K6 which doesn't have the sensor. So, what I want to know is...... How important is the sensor, if I disconnect it will it fook my bike up ? Would drilling a hole and welding a suitable nut on my K6 pipework to accept the sensor be a suitable solution ? OR..... Would I be better off just cutting my K8 pipework and using the already fitted sensor. |
#2 | |
The Sick Man
Its ok to drill hole and put sensor back in, weald has to be gas tight. The other possability is to find out the standard resistance of the sensor and put a resistor across the conector and you can remove the sensor, but my opinion is that it should be there.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#3 | |
Hope you enjoy the new bike! |
I don't know aything about a K8 specifically, but as general comments, that "honeycomb" will be a catalyst, I'd guess a metallic substrate rather than ceramic. That's where the clean up of the nasty regulated pollutants goes on, CO, HC and NOx.
Lambda sensors work a little bit like a battery, one side of the business end is exposed to exhaust gas, the other side of it is exposed to atmosphere. If it has free oxygen on both sides (i.e. the exhaust is "lean") there's no output, if the exhaust has no free oxygen ("rich") there is an output. The switching from hi-lo happens very close to a true stoichiometric air/fuel ratio (i.e. the chemically correct ratio for the fuel). The ECU uses this switching "feedback" to keep the mixture pretty well at stoich during most of the light load running (usually ignores the feedback and goes "open loop" at high load and maybe at a threshold high speed too). Removing the sensor will almost certainly cause some sort of running problem, and if the ECU doesn't see the response it expects you would normally get a "check engine" lamp come up. The ECU will default to some sort of "limp-home" mode usually.
"Artificial Intelligence is no match for natural stupidity" Last edited by embee; 05-01-09 at 05:46 PM. |
If you are fitting a slip-on I would keep the sensor (see TSM's post above), but for a full system I would dump it.
I'd leave it connected if at all possible, even with a full system - as Embee quite rightly says it only affects mixtures at idle/tiny loads anyway, so there's no benefit in not having it.
#7 | |
K1 Speed Sensor | ejohnh | Stuff Wanted | 3 | 17-03-09 02:50 PM |
Speedo sensor | phil24_7 | SV Talk, Tuning & Tweaking | 9 | 09-12-07 09:18 PM |
Speedo Sensor | djt_spurs | Stuff Wanted | 2 | 14-11-07 10:09 AM |
Air Temperature Sensor ?? | Blue Flame | Bikes - Talk & Issues | 4 | 04-11-07 08:10 PM |
General bike catalyser/fuel/sensor question | Anonymous | Bikes - Talk & Issues | 2 | 01-04-05 08:30 AM |
