Old 06-01-09, 10:20 AM   #1
DanAbnormal
Default Winter cleaning
As my bike is getting dirtier and dirtier I think I need to give it a good old wash but also to do a bit of maintenance to avoid the salt related issues later on.
Apart from the below what is else should be done:
Caliper clean with brake cleaning fluid (will take calipers off, remove pads and clean pins etc)
Clean and lubricate drive chain.
General wash and lube of all joints where applicable.
Cheers,
Old 06-01-09, 10:27 AM   #2
NickWilde123
Default Re: Winter cleaning
spray some fs 365 all over the exhaust and engine and fork each time you have finished riding and then when it gets dirty you just hose it down and it is back to brand new and then start the process again, its worked wonders for me this winter and thats with daily commuting even when we have thick snow
Old 06-01-09, 10:37 AM   #3
DanAbnormal
I got some ACF50 which should hopefully cover the corrosion. Cheers though.
Old 06-01-09, 10:39 AM   #4
NickWilde123
ye tell me if that is any good, the fs365 is good but i go though quite a bit of it reali quickly so the fc50 might be better in the long run
Old 06-01-09, 10:48 AM   #5
DanAbnormal
According to the manufacturers teh ACF50 only needs to be applied every few months which would save the hassle of cleaning the bike very weekend!! Will let you know how I get one. Cheers!
Old 06-01-09, 10:51 AM   #6
Stig
What you should have done is give the bike a good clean and then covered the bike with ACF50 BEFORE winter and then do not clean it again until the spring.
Old 06-01-09, 10:53 AM   #7
DanAbnormal
Indeed that would have been the ideal situation...........hindsight and all that!
Old 06-01-09, 10:53 AM   #8
NickWilde123
does it actually work that well??? and i enjoy cleaning my bike even if it is -2 out!!
Old 06-01-09, 10:58 AM   #9
Stig
The ACF50 coats the bike in a protective film. Dirt sticks to that film and more dirt sticks to the old dirt. All you have to do is look after the brakes because obviously you do not want to be spraying your brakes with the stuff.
Old 06-01-09, 11:11 AM   #10
DanAbnormal
It would make stopping an issue for sure.
Cleaning, how far do you take it? TheStudent SV Talk, Tuning & Tweaking 11 06-03-09 11:39 AM
Cleaning wheels clanger Bikes - Talk & Issues 11 05-07-07 03:59 PM
cleaning gettin2dizzy Bikes - Talk & Issues 13 21-03-07 02:58 PM
Cleaning? fizzwheel Idle Banter 17 15-02-06 09:17 PM
Cleaning Kit markfc SV Talk, Tuning & Tweaking 13 17-02-05 04:21 PM
