Old 06-01-09, 11:09 PM   #1
renman8957
Default K3 Parts
Hi, I'm in need of a few random K3 Sv650s parts. First off, need the rear brake pedal and the assembly for it as I can't get the old one off at all, bolt is mangled. Next, the 6 screws and metal tab pads for the headlight unit to screw onto, the two screws and rubber parts for the nosecone fairing (the ones basically furthest away from the nosecone), and may be in need of the headlight wiring loom if I can't get a hold of my original tomorrow.
Also, in the near future will also be needing a silver front nosecone in close to perfect condition if possible.
Thanks, and hope someone can be of help to me, appreciate any help given
Old 06-01-09, 11:15 PM   #2
husky03
Default Re: K3 Parts
brake pedal here mate-they have it listed as from a curvy but its a pointy-check there other sv stuff think they have hanger also
http://cgi.ebay.co.uk/suzuki-sv650-R...QQcmdZViewItem
husky
Old 07-01-09, 12:25 AM   #3
renman8957
Thanks, did a search and found a website where you can get universal lever pegs, so lever is sorted. May also require the speedo and headlight mounting bracket as mine seems to be bent. Thanks
Old 08-01-09, 05:04 PM   #4
Amplimator
Hi.... ive got a nosecone off a K3 silver ( yd8 ), it has a slight scuff on the right hand side tho, was quoted £60/70 for a touch up, it is totally solid and all lugs etc intact and is pristine everywhere else! it suffered from an embarrassingly slow off
i can post a pic if interested, would like to make it disappear for a 'sensible' price
reason for sale is missus brought me a new one (tho she wont say how much the new one was)
regards
Amp
Old 09-01-09, 10:59 AM   #5
renman8957
Excellent, yeh I'd be very interested, please post a pic. Cheers. Still after the screws and metal plates for the headlight unit, windscreen screw and rubber thing, and a couple of the rubber things required for fitting a lowerfairing, as well as the bolts, or just to know what size etc the bolts are so I can get some. Thanks
Old 09-01-09, 11:50 AM   #6
phil24_7
The screw for the headlight are cheap enough to buy from suzuki bud. You'd be looking at spending the same as getting them on here then paying for the potage probably!
Failing that, something like the clips and screws from car speakers would do the same job.
Old 09-01-09, 04:13 PM   #7
Amplimator
heres a pic as requested, lemme know if your interested
regards
Amp
WANTED: '99 sv650 parts or for parts moonshiner_19 Stuff Wanted 5 26-08-18 12:54 PM
K5 GSX-R parts. phil24_7 Idle Banter 3 17-05-08 07:50 PM
Need a few parts!! chris8886 Stuff Wanted 14 05-11-07 11:01 PM
Parts? mario SV Talk, Tuning & Tweaking 6 11-09-05 07:19 PM
K3 parts... Couerdelion SV Talk, Tuning & Tweaking 6 06-05-05 07:22 PM
