Old 14-01-09, 02:11 PM   #1
Jamie_SV
Default Sorry to ask but...rear shock?
After searching through loads of previous threads regarding the rear shock upgrade I have just about got it figured for my bike.... I think!
My bike is a 2001 sv650s, from what i can gather the best option would be an SRAD GSXR 600/750, or Kawasaki 636 shock. As neither of these drop the back end and fit pretty much straight in, with a little modification to the battery box.
Is this the case? and if so what year shock should i be looking at and are there any preferences to the GSXR or 636 shocks.
Cheers.
Old 14-01-09, 02:20 PM   #2
Luckypants
Luckypants's Avatar
Default Re: Sorry to ask but...rear shock?
How much do you weigh?
The shocks you list are all better than standard if they are not worn out. To that list you might also add ZX10-R shock or even a Hayabusa shock if you very heavy.
The reason I ask how much you weigh is that the spring strength on each one is different and so each one is better suited to different rider weights. I based my choice of replacement rear shock on my weight and type of riding (do a lot with pillion).
Old 14-01-09, 02:21 PM   #3
SRAD600 is too tall IMO. 750 is soft and tall, will put lots of weight on the front.
How much you weigh?
Old 14-01-09, 02:28 PM   #4
Mr Speirs
Mr Speirs's Avatar
Zx636 or Zx10r are the most sensible/cheaper options IMO. You can pick up quite new low mileage ones for not very much money. A little bit of modification (cut a playing card size hole in the battery box and put the battery onto its side.)
Old 14-01-09, 02:30 PM   #5
Jamie_SV
I weigh 80KG 13st in old money.
I just do weekend blasts the odd bit of touring and was planning on a track day this year, not much with pillion.
Going to fit hagon progs to the front along with SAE15 oil?
Old 14-01-09, 02:34 PM   #6
Any 2 up work?
Old 14-01-09, 02:39 PM   #7
Jamie_SV
Not enough to consider altering the bike for.
Old 14-01-09, 02:39 PM   #8
Luckypants
Luckypants's Avatar
I would think a ZX636 shock will be ideal or a ZX10 if you take pillion regularly - the ZX10 has a slightly stiffer spring.
Old 14-01-09, 02:43 PM   #9
Grinch
I have the B1H in mine, though the newer model is a better quality shock, mine seems to be fairing well this winter. You might find it a bit hard so make sure you have the setting right.
I think I have them somewhere...
Old 14-01-09, 02:44 PM   #10
Mr Speirs
Mr Speirs's Avatar
I though the spring rate for a Zx636 and Zx10r were the same.
Rear shock 03-08 silent11 For Sale - SV's and SV related items 0 17-05-08 02:53 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
rear shock socommk23 Bikes - Talk & Issues 1 23-04-07 05:09 PM
Rear shock latts650s SV Talk, Tuning & Tweaking 1 09-08-05 09:17 AM
Rear shock sprocket SV Talk, Tuning & Tweaking 3 17-05-05 10:50 PM
