Old 26-01-09, 09:51 AM   #1
The Guru
Red face Totally noob question about wheel balancing.
Ok, so I require a new front tyre. But will probably just get rear changed aswell as I will be changing front from factory Dunlop, so might aswell get a pair.
Im looking at getting Avon Storms fitted.
I have a replacement front wheel as the current one is marked. So do I switch over the brake discs etc before I get the tyre changed or do they just balance a bare wheel with tyre?
Old 26-01-09, 10:13 AM   #2
SVDragRacer
Default Re: Totally noob question about wheel balancing..
I'm no expert on this but i would have thought it'd make sense to get it balanced with everything on it that it would normally have when in use, obviously the disks/bolts/bearings could effect the balance of the wheel itself so balancing it with all the running gear on it would mean you get a perfectly balanced wheel for riding on.
I'm sure someone with a tad more knowledge/experiance will be along shortly, i was going with the logical approach.
Old 26-01-09, 11:23 AM   #3
The Guru
Yeah thats what I was thinking.. but just not 100% sure
Old 26-01-09, 11:24 AM   #4
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
balance the wheel in the state you're going to fit it to the bike, or as close as
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 26-01-09, 12:45 PM   #5
Dangerous Dave
Good choice, excellent tyres that suit the SV (remember that tyres are a personal preference too)
Balance the wheels with the discs on.
Old 26-01-09, 12:56 PM   #6
The Guru
I've no experience.. so I'll try them and see if I like them.
But I dont like the dunlops that are on it.. especially in wet.
Old 26-01-09, 02:43 PM   #7
In theory it should all be balanced as it will be fitted - in this case meaning with the discs, in reality it won't make a measurable difference.
Old 26-01-09, 02:46 PM   #8
AndyL
Snap!
Old 26-01-09, 04:22 PM   #9
Stu
Trinity
Stu's Avatar
just as well, as my wheels didn't get balanced at all
Seem fine anyway
Old 26-01-09, 05:39 PM   #10
Dangerous Dave
Thats the thing with all tyres, until you try them you won't know if they suit you and your needs. Tyres are a personal preference, a lot of people rate all sorts of tyres that I find horrible on the SV and they same the same about the Avon's.
They aren't bad but the aren't great either...
I wouldn't say they are terrible and you would need to change them straight away...
I wouldn't recommend them to be fitted as a second set simply because there are so many better tyres out there...
Can a noob ask a silly question? Jamie Slick SV Talk, Tuning & Tweaking 32 12-05-08 11:39 AM
How important is wheel balancing and do racers do it? monkey Bikes - Talk & Issues 15 25-02-08 08:44 PM
SV650 noob question catchsomesv650 SV Talk, Tuning & Tweaking 20 03-08-07 11:17 AM
Noob with a question? Lucky Luke SV Talk, Tuning & Tweaking 4 19-03-06 09:21 AM
Wheel balancing cuffy SV Talk, Tuning & Tweaking 14 12-01-06 08:02 PM
