Old 27-01-09, 01:36 AM   #1
COLZO
Default Tail Tidy Issue (Evotech)
Noticed the rear indicators were not as well fitted as the fronts so with some further investigation (new to bikes) I now know I have a Evotech tail tidy fitted. Does anyone with the same tail tidy find the indicators seem a bit slack? Also do I need a reflector for my MOT?
Any info much appreciated
Colin
Old 27-01-09, 01:43 AM   #2
Baph
Default Re: Tail Tidy Issue (Evotech)
You can buy spacers for the indicators to mount into properly - I also have an EvoTech tailtidy & found that the indicators had no-where to mount to without these spacers. Motrax sell them.
Perhaps you have the wrong spacers in there (small bits of plastic), or the're in the wrong way around - they come in two halves IIRC.
EDIT: These be the spacers... http://www.twowheel.co.uk/motrax-ind...r-spacers.html
As for the reflector, yes, you need one for the MOT. I got a red reflective sticker with the tail tidy, and put this onto the back of the numberplate light.
Old 27-01-09, 12:34 PM   #3
madness
If you unbolt the standard reflector from the big lump of plastic it can be mounted the bottom of your numberplate. I made up a neat little alloy bracket to do this. It cost nothing but a bit of time.
Old 27-01-09, 02:50 PM   #4
Amplimator
Dont evotech do 2 different models of tail-tidy for the sv? (one for the standard indies and one for mini indies if i remmy correctly) so if you need spacers, u got the standard indies tidy and have mini indies (i assume)
http://www.evotech-performance.com/a...Tail_Tidy.html
so basically if you have the standard indies one you will defo need the motrax spacers mentioned by Baph for the mini indies to fit correctly
Amp
PS i know i brought the standard one and my standard indies fitted just jubbly
Old 27-01-09, 03:58 PM   #5
TEL
TEL's Avatar
X 2
Blue naked K4
TEL is offline   Reply With Quote
Old 27-01-09, 04:10 PM   #6
COLZO
The tail tidy was on the bike when I bought it and it has still got the original indicators. They fit but I can still move them slightly (e.g. I can turn them to 5 past or 5 to - if you know what I mean???). Is this right or am I missing some parts from the original. There is a rubber cushion and backing plate where the wire and bolt go through and the bolt is tight if this helps?
Thanks again.
Old 27-01-09, 04:17 PM   #7
TEL
TEL's Avatar
iirc i fitted a few extra washers on the end of the stems .... wasn't dead tight but made them more stable
Blue naked K4
Old 27-01-09, 04:20 PM   #8
Amplimator
hmmmmmm strange as mine were a good tight fit, i used the original spacer fingies from my snow shovel too (the plastic backing plate fingamajigs)
id use a coupla glue gun spots to seal em in, reason i suggest a glue gun is coz u can jus peel it off when removed unlike super-glue etc
jus my bodgetastic idea thos
Amp
Old 27-01-09, 09:37 PM   #9
skeetly
skeetly's Avatar
I added some washers to mine.
skeetly is offline   Reply With Quote
Old 27-01-09, 09:47 PM   #10
DOM B
i fitted an evotech tail tidy only a few months back , my indicators are standard and fit perfect , i must say this was one of the easiest parts i've ever fitted , with step by step instructions , i guess whoever fitted yours may have missed something or done something wrong ?
Evotech Tail Tidy Needsy For Sale - SV's and SV related items 5 20-04-08 09:04 PM
EVOTECH Tail Tidy - Help!!! krhall Bikes - Talk & Issues 31 11-03-08 03:54 PM
Evotech Tail Tidy TEL Ancillaries 3 25-11-07 03:34 AM
EvoTech Tail Tidy M65 SV Talk, Tuning & Tweaking 7 14-10-06 09:56 AM
evotech tail tidy? garyh74 SV Talk, Tuning & Tweaking 6 07-10-06 04:28 PM
