Old 27-01-09, 08:00 PM   #1
manicmonkey
Question Help I'm losing oil (Actually it's my bike that's losing oil).
Hi, I've got a K6 on nearly 8000 miles and ive started to lose oil. I noticed the other day when doing my first mod (exhaust) and I must have put about a litre in to fill it up to the high mark. Since then I've done a couple hundred miles and its gone down to half way between high and low (the middle!).
I've had a look in the filler cap and there is no 'mayo', and I haven't seen any oil patches on the ground where I park.
Is there a common fault which would explain this? What should I do? Should I wait for it to get worse so that it is easier to diagnose? I assume other problems will crop up and highlight the problem area...
I want to drive to Germany and back in a couple of weeks but it feels a bit risky now...
DONT PANIC!! DONT PANIC!!
Old 27-01-09, 08:02 PM   #2
arcdef
Default Re: Help im losing oil!
If you are wanting to go to Germany in only a few weeks i would just take it to a garage straight away. No point doing one thing to solve it, then finding out half way there that its still leaking!
Old 27-01-09, 08:06 PM   #3
pmapp
pmapp's Avatar
Are you checking the level with the bike upright and on flat ground?
Old 27-01-09, 08:08 PM   #4
manicmonkey
Yeah I was kinda hoping it would be something simple I could fix myself but I guess this is unlikely, and it probably wont get better on its own... At the moment I think I will risk the trip to MCN on saturday and take it into a garage on monday. Still, it would be nice to have an idea of the problem
Old 27-01-09, 08:08 PM   #5
manicmonkey
Yep thats right, I just sit on the floor and pull it towards me until it feels like its gona topple over and squash me!
Old 27-01-09, 08:09 PM   #6
Mr Speirs
Mr Speirs's Avatar
Also if you have just turned the engine of it'll take a good few mins for the all oil to drop back down.
Old 27-01-09, 08:11 PM   #7
manicmonkey
This is a good point, I did check it only a minute after switching it off. I'll go check it again now...
Old 27-01-09, 08:20 PM   #8
manicmonkey
Ok, so its about millimeter above halfway. I did find out the oil is silkolene super 4 10w40
Old 27-01-09, 08:29 PM   #9
With that sort of consumption I would personally just keep topping it up.
Old 27-01-09, 08:30 PM   #10
fizzwheel
fizzwheel's Avatar
What colour is the exhaust smoke when you start the bike up first thing in the morning, does it smell oily when the bikes running ?
losing a loved one. Frank Idle Banter 23 27-02-09 09:19 PM
Still losing power? Baz SV Talk, Tuning & Tweaking 12 21-12-08 06:42 PM
Bike losing power / cutting out Baz SV Talk, Tuning & Tweaking 76 24-11-08 07:49 AM
Losing the plot... Stingo Idle Banter 0 29-02-08 09:18 PM
Losing the limiter ThEGr33k SV Talk, Tuning & Tweaking 45 27-08-06 12:05 PM
