Old 29-01-09, 11:02 AM   #1
Mr Speirs
Mr Speirs's Avatar
Default Caliper Pistons: Ok to Spin?
Hi just wanted some reassurance. Just giving the calipers a bit of a spruce.
Im currently cleaning the road dirt off the end of both pistons but can't get to the other sides. Is there any reason I shouldn't just spin them round?
Thanks
Old 29-01-09, 11:06 AM   #2
leegriffiths128
Default Re: Caliper Pistons: Ok to Spin?
I'm no expert, but have always spun mine round for easier cleaning...no problems so far
Old 29-01-09, 11:14 AM   #3
Mr Speirs
Mr Speirs's Avatar
ok next question. Any tips on how to spin them round. Mine don't wanna spin.
Old 29-01-09, 11:15 AM   #4
arcdef
be easier just to take them out and give them a proper clean
Old 29-01-09, 11:17 AM   #5
Mr Speirs
Mr Speirs's Avatar
Yeah I realise that but I am replacing the fork oil as well and need to be out on the bike saturday. I don't really have a lot of time. Its just while the calipers are hanging loose its tempting to give them a spruce.
Old 29-01-09, 11:19 AM   #6
arcdef
i probably would worry then and wait for a time to give them a full going over another time?
Old 29-01-09, 11:23 AM   #7
Mr Speirs
Mr Speirs's Avatar
I will give them a full overhaul but for the time being Im just guna get them looking nice.
Old 29-01-09, 11:34 AM   #8
IF they will spin then feel free, so long as you have pumped them out a bit and they are not covered in $hite where you are going to rotate them.
However, they are usually pretty tight in the bores so won't.
Better to use a bit of thin card with some solvol on it, or the serrated edge of a cable tie to clean around them.
Old 29-01-09, 11:37 AM   #9
plowsie
YC is this a good guide to go by? They say WD40, surely thats asking for trouble...
http://www.motorcyclenews.com/MCN/ad...ce/?&R=EPI-668
Old 29-01-09, 11:48 AM   #10
I have seen worse "guides" (bluepoof...). That doesn't seem too bad but if they are properly seized then that type of cleaning will do sod all.
I would not use WD40 as it contains paraffin. Use a fast evaporating brake cleaner, or work dry and blow any dust off. Then use red rubber grease as you push the pistons back.
Still, there's no substitute for a proper service.
Caliper pistons Sean_C Bikes - Talk & Issues 16 17-10-08 04:44 PM
You spin me right round.... ooger Idle Banter 4 21-04-08 11:03 PM
First spin on an SV Durbs Bikes - Talk & Issues 29 28-11-07 08:28 AM
out for a spin... valleyboy South & West Surfers 17 27-03-07 08:19 AM
Journo goes for a spin in an F18... philipMac Idle Banter 11 11-05-06 05:48 PM
