Old 01-02-09, 04:01 PM   #1
imhg
Question Can't find 1st, 2nd or 3rd gear
Hi
I have a 02 650s, and I can't seem to find 1st, 2nd and somestimes 3rd gear when I change down at low revs. However, at high revs everythings seems to be okay!
Does anyone have a clue what is going on with my bike?
Old 01-02-09, 04:03 PM   #2
hovis
Default Re: Can't find 1st, 2nd or 3rd gear
have you checked behind the sofa?
Old 01-02-09, 04:08 PM   #3
thefallenangel
check front sprocket cover isn't cruded up and check it adjusted properly.
Old 01-02-09, 04:09 PM   #4
Alpinestarhero
Check: chain tension, chain lubrication (if its dirty, clean it with parrafin and then lubricate with something like Wurth or silkolene messy stuff or something), check your engine oil level, check and adjust the clutch (you will need to take off the plastic cover to reveal the front sprocket and clutch worm drive mechanism - there is a post by sid squid on how to do the worm drive adjustment. Simply adjusting the cable is not enough to properly adjust the clutch!)
Also, lubricate the gear change shaft
Cheers,
Matt
Old 01-02-09, 05:35 PM   #5
Dangerous Dave
First check the gear lever and linkage isn't slack, then check the chain tension is set up correctly (20-30mm)
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Where can I find clutch housing bolts? - Cant find any mikeSV SV Talk, Tuning & Tweaking 2 24-03-08 12:30 PM
New Gear changer, cant find 1st Renton SV Talk, Tuning & Tweaking 1 14-11-07 12:57 AM
