Old 10-02-09, 06:33 PM   #1
squariegoes
Default SV650s 2006 model horn not working?
Hi, the horn has stopped working on my bike. I only realised this however when a car almost drove into me. I haven't checked the fuse yet but after reading the manual I don't think changing the fuse will make a difference as according to the manual, the same 10 amp fuse is used to protect the speedometer and this is still working.
Does anybody have any ideas as to why the horn isn't working?
Old 10-02-09, 06:42 PM   #2
Default Re: SV650s 2006 model horn not working?
No.
Old 10-02-09, 06:43 PM   #3
Baph
Let the bike cool down & see if it works. Heat is a common problem for the SV horn.
Old 10-02-09, 06:56 PM   #4
svdemon
Bend it away from the radiator.
Old 10-02-09, 06:58 PM   #5
flymo
flymo's Avatar
whip the lead off and check for voltage with a multimeter when you 'peep' the horn. If you get voltage (around 12v) then either its a knackered horn or a dodgy earth where it mounts.
Old 10-02-09, 07:05 PM   #6
Horn doesn't earth through it's mounting.
Old 10-02-09, 07:11 PM   #7
Baph
+1. Negatively switched IIRC.
Old 10-02-09, 07:17 PM   #8
newts924
I have been told that the horn gets very hot and stops working, try moving the horn to an other place on the bike, away from the radiator.
Old 10-02-09, 07:29 PM   #9
flymo
flymo's Avatar
Ah, I see. I've replaced too many Transit horns lately
Old 10-02-09, 07:33 PM   #10
jaffacakes
+1 - happens quite often
Horn not working shonadoll SV Talk, Tuning & Tweaking 19 19-02-09 07:16 PM
Horn not working ranathari SV Talk, Tuning & Tweaking 2 01-09-08 07:32 PM
Horn not working. SAMMY650 SV Talk, Tuning & Tweaking 7 13-05-08 08:26 PM
Air horn not working. therealvw Bikes - Talk & Issues 4 24-07-07 07:25 AM
Horn not working... mikew SV Talk, Tuning & Tweaking 10 21-06-07 01:04 PM
