Old 12-02-09, 06:24 PM   #1
Baph
Default K6 compatible Front brake switch
As title. Anyone got one?
Old 12-02-09, 07:31 PM   #2
Sideshow#36
Default Re: K6 compatible Front brake switch
I may still have that fitted on my race bike. I take it you mean the ine that is mounted under the lever/mount and makes the clicky noise when you pull the lever in? Its off a K4 by the way.
Old 12-02-09, 10:35 PM   #3
Baph
That's the jobby. Has a 2 pin connector attached to it when in use, and there's a single screw to hold it to the underside of the lever.
Mine's a little intermittent.
Old 12-02-09, 11:12 PM   #4
SoulKiss
SoulKiss's Avatar
I might have a spare - let me check the garage in the morning
Front brake light switch svrash Stuff Wanted 0 21-03-07 11:01 AM
FRONT BRAKE SWITCH, 99 CURVY Well Oiled Stuff Wanted 1 07-06-06 01:10 PM
Replacing the Front Brake Light Switch fizzwheel SV Talk, Tuning & Tweaking 2 23-03-06 02:11 PM
Front Brake Switch - is it me?? embee SV Talk, Tuning & Tweaking 8 01-08-05 04:21 PM
Front brake switch? Bikerz SV Talk, Tuning & Tweaking 4 18-05-05 07:52 AM
