hi everyone
i have a new problem on my k3 when switching ignition on sometimes the fuel pump does not make its usuall whirring noise on pre startup check. if i turn ignition off and back on it is fine. but today it happen 3 times where it made a short whirring noise and stopped on fourth time it was ok. any ideas on what this might be is it a minor or major problem thanks chris |
Sounds like a lose connection to me, lift the tank up and have a look at all the connectors under there make sure there all fully pushed to geather. Also this could be a long shot but check the kill switch wire is fully connected because if its a bit dodgey it could be why it keeps cutting it out, Dom
same thing happens to my k3 after a cold night occasionally,
im assuming its down to the pump being sooooo cold having petrol around it all night, and probably needing to good clean out. |
I've got Exactly the same thing, short buzz several times with the dreaded FI indication, before the proper loooong whirr, did you get a definitive diagnosis and solution?
Pointy K3S in SuperSonicSilver, R&G bungs, Carbon Can Co slip-on SOLD TO MEMBER "Cobra"! So long old friend! I'm going all Charley Boorman on yo' ass. Can't filter or indicate any more. |
I'd say more likely to be other safety systems on the bike, the pumps themselves tend to be pretty reliable
Agreed. I've seen a couple of failed pumps, but more often when the problem is traced to the pump itself it's been iffy connections/wiring.
Fuel pump not coming on. | mackrilld | SV Talk, Tuning & Tweaking | 5 | 05-11-10 05:00 PM |
How do i remove the fuel pump on a K5 | tonny006 | SV Talk, Tuning & Tweaking | 10 | 01-10-08 08:45 PM |
Fuel pump | cornishrider | SV Talk, Tuning & Tweaking | 6 | 02-03-08 07:25 PM |
K5> fuel pump | phil24_7 | Stuff Wanted | 11 | 29-10-07 05:18 AM |
No dash + fuel pump | ivantate | SV Talk, Tuning & Tweaking | 3 | 30-06-06 04:22 PM |
