Old 18-02-09, 09:00 AM   #1
COLZO
Default Torque Settings - Spark Plugs & Oil Drain Bolt
Found a service manual for a K3 which says the torque settings for the spark plugs is 11nm and oil drain bolt is 21nm. Would this be the same for my K6?
Old 18-02-09, 09:08 AM   #2
Viney
Default Re: Torque Settings - Spark Plugs & Oil Drain Bolt
Yes.
Old 18-02-09, 09:56 AM   #3
timwilky
timwilky's Avatar
personally I would say never use a torque wrench for these, in over 30 years of using spanners, I have never stripped a plug or drain thread. But have had to pick up the pieces when others have.
Do it by feel. Neither are fasteners, they simply need to be tight enough to stay put.
Not Grumpy, opinionated.
Old 18-02-09, 10:17 AM   #4
No do not torque a spark plug. Read the back of the box. IIRC it's finger tight then 1/4 turn or something to seat the crush washer, but check because it could be 1/2 a turn.
Use a little copper slip on the threads.
Sump plug, as above.
Old 18-02-09, 10:13 PM   #5
COLZO
To be honest I thought it was a bit OTT for torque settings on these parts but just wanted to be sure.
Front & rear brake bolt torque settings required. svsk2 SV Talk, Tuning & Tweaking 2 02-05-09 04:13 PM
torque settings carlSV SV Talk, Tuning & Tweaking 2 01-06-06 10:24 AM
Torque settings Daimo SV Talk, Tuning & Tweaking 7 12-09-05 04:04 PM
Oil drain bolt not tightening to specified torque Raf SV Talk, Tuning & Tweaking 32 10-04-05 12:24 PM
TORQUE SETTINGS chewy22 SV Talk, Tuning & Tweaking 1 20-02-05 07:58 PM
