Old 18-02-09, 12:59 PM   #1
branny
Default Oily right foot
this one has been confusing me for a while... my right boot gathers oil on the instep of the toe area.
very strange... where can this be coming from? i have a scottoiler but i assume more oil would come out of the left hand side if any.
very random i know!
Old 18-02-09, 01:01 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Oily right foot
Clutch cover leaking?You should be able to see if oil is coming out and covering other bits of the bike.
Old 18-02-09, 01:05 PM   #3
branny
i honestly can't see any oil anywhere on the RH side! Not any sign of oil on the engine face either.
just on my boot... very strange!
ps. yes i have cleaned it off and it came back!
Old 18-02-09, 01:06 PM   #4
hovis
have you checked to see if the bike is losing oil?
Old 18-02-09, 01:10 PM   #5
branny
it doesn't appear to be losing any oil, like i say, i can't see any sign of where it could come from to get on my boot... considering my toe is always alongside my brake pedal.
Old 18-02-09, 01:20 PM   #6
theres a rubber breather hose that runs down the side of the clutch cover sideClipped on with a clamp on one the bolts IIRC) .....could be from there?
Old 18-02-09, 01:20 PM   #7
vardypeeps
My Bandit had a very slow leak from the rhs of the engine as one of the bearings had gone and the gasket had a little hole in. My foot got covered also in oily dirty stuff.
Have you tried checking your oil filter to see if it's attached properly?
Old 18-02-09, 01:22 PM   #8
branny
The rubber breather hose interested me too... i assumed it was a fuel overflow, no?
This problem is apparent now and also predates an oil/filter change.
The Bandit problem sounds similar.
Old 18-02-09, 01:29 PM   #9
vardypeeps
Have a feel around and see if you can find the same substance on the bike anywhere?
Old 18-02-09, 02:44 PM   #10
branny
on closer inspection... it could possibly be coming from under the clutch cover.
Cleaning Off Oily Muck chris8886 Bikes - Talk & Issues 28 01-01-08 08:55 PM
wanted - foot peg and foot brake lever bikerman Stuff Wanted 2 03-10-06 10:47 AM
Where is the foot? localhost Idle Banter 25 06-05-06 07:31 PM
Someone drove over my foot! northwind Idle Banter 28 01-05-06 05:22 PM
Trench-foot? Jabba Bikes - Talk & Issues 10 03-12-04 03:38 PM
