Old 20-02-09, 05:24 AM   #1
ZJIN1985
Default crack sound from neutral to first gear
I just bought a 03 SV650S, and everytime I change from neutral to first gear, I can hear a loud 'crack' sound no matter if the bike is warmed up.
Is it normal? Thanks.
And also the front brake doesn't feel good. I can't feel there's enough initial bite. It's like everytime I brake, I really need to pull the brake lever in hard, otherwise the bike just doesn't feel like to stop. The brake fluid has just been changed, and the mechanic said there's still enough brake pad left.
Old 20-02-09, 07:44 AM   #2
Tomtoms
Default Re: crack sound from neutral to first gear
as far as i know the 'crack' is normal. i get it when the bike is cold, or bin left idling for a few minutes....
someone will give a more technical description for you soon!!
Old 20-02-09, 08:28 AM   #3
Check clutch adjustment. Hold the lever in for a second or two before selecting first.
Old 20-02-09, 08:51 AM   #4
plowsie
Hi revvs also make it do it, I sometimes accidently kick mine in when its got choke on,
"fockin ell" is what I normally say after the heart wrenching CRUNCH!
Old 20-02-09, 06:33 PM   #5
jimmy
mine does it, very annoying
Old 20-02-09, 07:09 PM   #6
jumjum_0214
Check the tension of your chain
Old 20-02-09, 07:17 PM   #7
Sally
Mine kinda does it too, thats with a new chain on, and only done 50~ miles with it.
Tension is bang on too..
Just one of the things av got used to..
Old 20-02-09, 07:21 PM   #8
startrek.steve
All bikes do it dont they? its a wet clutch thing...
if you think an SV is noisy, try putting a 1965 Triunph into gear!
Steve
Old 20-02-09, 08:25 PM   #9
pmapp
pmapp's Avatar
Regarding your brakes, it sounds like there is still air in the system - especially if the fluid has just been changed.
Old 20-02-09, 08:26 PM   #10
charlie13
+1 on correct clutch and chain adjustment. And did I imagine it or did I read niall mac mention in TWO recently that if you roll it forward a few steps with the clutch in before you engage 1st it goes in a bit easier without so much noise? Seems to work when I try it in the flat car park at work, not so easy up the steep path at home.
Carbon can - with a crack! AndyBrad SV Talk, Tuning & Tweaking 24 03-11-08 03:16 PM
My crack has gone.... Girth Idle Banter 17 13-08-08 06:29 PM
can you crack this? Dave The Rave Idle Banter 9 11-03-08 03:56 PM
can you crack this? Dave The Rave Idle Banter 71 17-02-08 08:50 PM
Gear (neutral) problem... MavUK SV Talk, Tuning & Tweaking 9 03-05-05 11:46 AM
