Old 20-02-09, 02:23 PM   #1
stuballs
Default Hose size for bleeding brakes?
6mm? 8mm?
cheers
Stu
Old 20-02-09, 02:29 PM   #2
shifter
Default Re: what id pipe do i need to fit the front claiper bleed nipple?
Don't know the figures, but I tend to go for something under size then warm the end with a lighter. Push it over the bleed valve while it's still semi melted and let it cool in situ. You normaly find it moulds itself to the right shape for a good airtight fit then.
Old 20-02-09, 03:00 PM   #3
stuballs
yeah that's what i do but not sure if i should start with 6mm or 8mm. I supopse I'll start with 6mm.
Old 20-02-09, 06:01 PM   #4
shifter
Most D.I.Y stores stock various sizes of plastic tube if I remeber corectly
Old 20-02-09, 06:12 PM   #5
sweepdoggydog
Default Re: Hose size for bleeding brakes?
I used a 6mm tube last time which worked well
Bleeding Brakes - Again HopefullySoon SV Talk, Tuning & Tweaking 2 28-08-07 09:13 AM
Bleeding Brakes (Bleeding Kits) 21QUEST SV Talk, Tuning & Tweaking 8 20-06-06 05:31 PM
Bleeding Brakes sweepdoggydog SV Talk, Tuning & Tweaking 9 08-06-06 07:07 AM
Bleeding brakes Samurai SV Talk, Tuning & Tweaking 6 06-06-06 05:17 PM
Bleeding Brakes Moo SV Talk, Tuning & Tweaking 9 21-01-06 07:59 PM
