Old 20-02-09, 05:08 PM   #1
wilky007
Default New indicators fitted - not working right.
Hi all i have just fitting some new led inaictors to my bike but only 1 side is working right 1 side as full led and the other only has 3 working swoped the wiring round an the other one works an the other has 3 working please help cheers
Old 20-02-09, 05:29 PM   #2
ophic
ophic's Avatar
Default Re: advise please
Are they Motrax? Mine do this when the engine is off. Altho, both of mine do it - not just one.
Silver SV650SK3, Fuel exhaust
Old 20-02-09, 09:40 PM   #3
wilky007
they are all working now but i think they are on speed flashing way to fast
Old 20-02-09, 09:49 PM   #4
Dave20046
Dave20046's Avatar
You need a different flasher unit in.
Old 20-02-09, 10:11 PM   #5
fizzwheel
fizzwheel's Avatar
Or a few pence worth of resistors.
Its been covered before but LED indicators flash to fast and you need to wire in a resistor and that sorts it. I cant remember why or the exact technicalities of it, but if you do a search you'll find plenty of threads on the subject.
Old 20-02-09, 10:15 PM   #6
wilky007
they came with the inline resistors which i have installed
Old 20-02-09, 10:19 PM   #7
fizzwheel
fizzwheel's Avatar
OK well thats me stuck then, sorry I cant help anymore, but somebody should be along shortly who can.
Old 20-02-09, 11:32 PM   #8
keith_d
keith_d's Avatar
<Keith puts geeky head on...>
Individual LEDs generally run on around 1.4 volts with a fixed current, typically around 0.02 to 0.04 amps per LED. If you connected one directly to a bikes 12V supply it would fry instantly, so a resistor is connected in series to limit the current through the LED.
Unfortunately, the flasher circuit has a clever feature. It uses the current through the bulbs (typically 0.5 to 1 amp) to determine the frequency, the idea being that when one bulb fails it flashes faster to warn you. If you replace your bulbs with LEDs you're using a lot less current, so the flash rate increases.
There are two ways around this. Either replace the flasher unit with one that's suitable for the low current drawn by LEDS, or stick a 33 ohm 10 watt resistor across the LEDs to draw enough current for your existing flasher.
<removes geeky head>
Old 21-02-09, 04:31 AM   #9
BanannaMan
BanannaMan's Avatar
Wow!!! The new model comes with a software upgrade!
...Bill
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
Both right side indicators not working ;( drefraser SV Talk, Tuning & Tweaking 22 05-11-07 09:58 PM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
