Old 20-02-09, 09:50 PM   #1
evilexel
Default Tyre Pressure
Hi all,
i have a the K3 SV650S with a high level scorpion can, ive just had my restriction took off today and had a new front tyre put on but now my question is, Does anone know the correct pressure for Dunlop Roadsmart tyres or for the SV in general ?
cheers
Evilexel
Old 20-02-09, 09:52 PM   #2
Default Re: Tyre Pressure
check your tyre manufacturers website.
hello and welcome to the mad house BTW
Old 20-02-09, 10:09 PM   #3
fizzwheel
fizzwheel's Avatar
Start with standard pressures, which are 33 front and 36 rear and then adjust from there to suit how you ride... dont change them to much 1 or 2lbs will probably be enough for you to feel and evaluate the difference.
Old 20-02-09, 10:45 PM   #4
stevebetts
Hi - i have it on good authority that 36 front and 42 rear works fine accross the board. This came from a pirelli technician.
I have used this on all of my bikes and it works well.
cheers
Old 20-02-09, 10:50 PM   #5
thefallenangel
34 and 38 i'm currently running but 35 and 40 felt better but shagged chain didn't like it so i'm back at 34/38.
As long as the rear is 3-6psi more than the front it should be fine but it also depends on how the front end behaves too.
Old 20-02-09, 10:57 PM   #6
cheers
might be fine for Pirelli, but Avons are 33 36. They feel carp any higher to be honest.
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
Tyre losing it's pressure thedonal Bikes - Talk & Issues 10 27-01-07 03:12 PM
What's your tyre pressure? Diveboy SV Talk, Tuning & Tweaking 28 03-05-06 07:05 PM
FRONT TYRE PRESSURE................ alexb SV Talk, Tuning & Tweaking 12 23-01-05 04:39 PM
Tyre pressure? Rodger Wabbit SV Talk, Tuning & Tweaking 10 24-11-04 12:23 AM
