Old 21-02-09, 11:20 PM   #1
sv_rory
Default light front end
What would make a front end feel really light and a little twtichy?
i have just had new headstock bearings fitted and also wheel bearings so im not sure why it feels like this.
What would be the first obvious things for me to check? all the bolts and everything are fine.
cheers
Old 21-02-09, 11:25 PM   #2
Lissa
Just Ballast
Lissa's Avatar
Default Re: light front end
Did you put the forks back in at the same height as they came out?
Old 22-02-09, 12:22 AM   #3
sv_rory
Yeah i measured them and they were perfect, i remeasured them to see if they have moved at all and they are still spot on
Old 22-02-09, 09:06 AM   #4
zadar
did this just happen after you changed bearings or was it there before?
Old 22-02-09, 09:47 AM   #5
Sean_C
I have gsxr forks and had ohlins shock on full ride height, which felt very light and twitchy to me. Have you got a standard shock or something else?
Old 22-02-09, 10:11 AM   #6
shifter
Add more preload to the rear shock. That will effectivly tilt the bike forwered and add more weight to the front end
Old 22-02-09, 11:09 AM   #7
sv_rory
i havent adjusted any preload or anything so why would it now feel extremely light
Old 22-02-09, 11:14 AM   #8
shifter
Perhaps your old bearings where shot, and now you have new ones it all feels a lot lighter because they are working properly?
Old 22-02-09, 11:22 AM   #9
sv_rory
i had that in mind to be honest, the old bearings were shot.do you think it will settle down if it is?
Old 22-02-09, 11:24 AM   #10
fizzwheel
fizzwheel's Avatar
When my bikes handling weird, First thing I check is the tyre pressures...
Brake light switch on front lever plowsie SV Talk, Tuning & Tweaking 1 01-08-07 11:48 AM
Front brake light switch svrash Stuff Wanted 0 21-03-07 11:01 AM
Replacing the Front Brake Light Switch fizzwheel SV Talk, Tuning & Tweaking 2 23-03-06 02:11 PM
Front level brake light switch? Bikerz SV Talk, Tuning & Tweaking 3 16-05-05 07:30 PM
Front Light Removal? Rodger Wabbit SV Talk, Tuning & Tweaking 5 22-12-04 01:40 PM
