Helmets Post your own reviews, opinions and experiences on this subject.
Old 26-02-09, 06:59 PM   #1
arcdef
Default problem with shoei raid 2?
had my Shoei since November now and in the last week it has started to let a noticeable amount of wind through the visor seal, i cant figure out where/why its doing it but is very annoying at 70 when you eye starts watering!
Pretty much have i got any come back to get it replaced/repaired or is it way too late now?
Cheers.
Old 26-02-09, 07:30 PM   #2
Default Re: problem with shoei raid 2?
is the visor clipped in right?
Old 26-02-09, 07:35 PM   #3
sarah
I get that sometimes with my raid II too.
I think kwak is on to something though...
Old 26-02-09, 07:40 PM   #4
arcdef
As far as i can tell its clipped in fine, didn't think it was possible to put it in any way but right, ill have a fiddle and see if its still doing it next time im out. Im guessing there's nothing i can do other than this?
Old 26-02-09, 07:43 PM   #5
keith_d
keith_d's Avatar
If the visor is lifting slightly you might try using the catch on the left hand side to lock it down and see if that helps.
Keith.
Old 26-02-09, 07:44 PM   #6
arcdef
Keith.
Good idea, hadn't even thought of that .
Cheers!
Old 26-02-09, 07:49 PM   #7
FG1
Check the screws holding the plates to the lid. I had a Z-one and after a while one came loose and I had a similar issue. A doddle to correct if this is the problem. If they are tight, try adjusting them so you get a better seal.
Old 26-02-09, 07:56 PM   #8
sarah
Ooh, good idea. Just tightened mine. Hope it does the trick.
Old 26-02-09, 10:22 PM   #9
thebluelion
I have had mine for about 2 years and never had a problem. I thinking maybe a slight fault, could be a one off. Take it back and complain see what happens
Old 28-02-09, 12:51 PM   #10
chris8886
chris8886's Avatar
Cheers.
i get this with my raid I. it really annoys me and i've never managed to figure out a solution, which is why i've decided i'm buying arai next time as long as it fits properly, but that's not going to be for another year at least
AR08 to AR13-QUALITY!
AGV Stealth or Shoei Raid ll ? SV Muppet Helmets 13 26-01-08 05:27 PM
Shoei Raid 2 ejtrent Helmets 4 09-08-07 06:10 PM
best price on Shoei Raid II bradkarma Helmets 1 14-07-06 03:22 PM
Shoei raid 2 tigersaw Helmets 17 01-05-05 02:29 AM
Shoei raid 2 kyle210483 SV Talk, Tuning & Tweaking 9 04-01-70 12:19 PM
