Old 01-03-09, 11:46 PM   #1
Sally
Default Nylon Bush for Left Rearset.
When i first took my rear set apart, to clean inside it and that, i broke/torn the nylon bush.
Not sure where to get a replacement, or alternatively, has anyone got one lying around i can buy off them..
Not the most usual question i know,
Cheers, David.
Old 02-03-09, 12:02 AM   #2
petevtwin650
Default Re: Nylon Bush for Left Rearset.
Cheers, David.
I broke mine when greasing it. Just reassembled the lever without it. Ok it was a bit floppy but it worked perfectly fine and I never had to worry about the seizing issue after either. They are not available seperately from the lever.
Old 03-03-09, 03:08 PM   #3
Sally
Ye it seems to be giving me some problems, its slightly broken, but is still in place..
Think i should just remove and I would be fine?
Taking them apart every 2 weeks, as theyre getting stiff, so i think its causing some problems.
Old 03-03-09, 05:40 PM   #4
madness
Go to B & Q, motor factors or wherever, find some plastic tube the right size, buy a bit, and then hacksaw it to length. Job done.
WTB: 1 gen left side REARSET hoknight Stuff Wanted 3 03-02-09 06:28 AM
curvy left side rearset wanted trouty Stuff Wanted 0 15-09-08 05:33 PM
Left hand side fairing and left mirror plowsie Stuff Wanted 13 13-09-08 08:51 PM
k5 pointy left footpeg, gear changer assembly and left front indicator - will pay good money Paul the 6th Stuff Wanted 2 21-04-08 09:03 AM
Nylon, made by Me Alpinestarhero Photos 29 21-03-07 06:04 PM
