Old 03-03-09, 10:52 PM   #1
Default CDI Magneto Wiring
I'm looking for some wiring help for my TZR. Bit of a long shot but maybe someone will have an idea
I've got 10 cables coming from the CDI magneto/Pick-up coil. Red, green and brown are going to the CDI unit. White/red and white/green also go to the CDI unit. I also have a blue and a black which have both been chopped. Where should they go?
Then there are the 3 white cables which go to the rec/reg. Does it matter which is which?
Old 04-03-09, 12:05 AM   #2
Default Re: CDI Magneto Wiring
Have you got a wiring diagram for it?
http://www.carlsalter.com/motorcycle-manuals.asp
Old 04-03-09, 12:45 AM   #3
rictus01
rictus01's Avatar
Hmmm well stating if it's the 125 or 250 might help, for a start and if the 125 I believe it's the same engine as the DT125, from memory (and I'm stretching here) the generator (no it's not a magneto) pickup has only two wires coming out, but they joint with another two pairs these all go back to the ignition unit (yes I know the haynes call it a CDI), the three whites go to the reg/rec and should terminate in a plug which fits only one way.
that's about as much as I remember, but I'd check if I was you, it was a while back.
Cheers Mark.
Old 04-03-09, 10:09 AM   #4
Yeh I've got a diagram but there doesn't seem to be a blue or black coming from the magneto. It does show the three white cables but doesn't say if it matters if they are swapped. They don't have a connector on them because they have also been chopped
It's a 1989 TZR250 2MA. Here's the diagram
(1) rec/reg
(2) CDI Magneto
(9) CDI Unit
(10) Pick-Up Coil
Old 04-03-09, 11:15 AM   #5
Are you sure it's coming from the actual generator assembly? Could it be neutral light wires? That's a blue wire on my RD400E
Old 04-03-09, 11:23 AM   #6
No I'm not sure, but the 10 cables are all bunched together and come from that area. What do you mean neutral light?
Black is the neutral/earth on the rest of the bike's wiring
Old 04-03-09, 11:25 AM   #7
Have a look at the other end of the bunch and see where they are from.
Neutral light... that green thing that lights up in between 1st and 2nd gear
Old 04-03-09, 11:27 AM   #8
Derrrrr what a muppet. I had my electrical hat on, not my bike hat
I'll have a look
Old 04-03-09, 11:30 AM   #9
The neutral indicator light is (14) on the diagram so it doesn't seem to go directly to the magneto
Old 04-03-09, 11:33 AM   #10
No but the gear position switch could quite possibly be around the same area, on my yam the neutral indicator switch is a couple of inches behind the magneto/generator assembly, and the wire comes up in the same chunk of loom.
Easy test, pull the front sprocket cover off (or is it whole side-case?) and have a look.
Signal Generator and Magneto Grinch Stuff Wanted 5 25-11-08 04:57 PM
Re-wiring Caddy2000 Bikes - Talk & Issues 4 27-09-07 12:56 PM
Magneto Cover andym8 Stuff Wanted 2 04-10-06 02:20 PM
f1 wiring sv650s_guy SV Talk, Tuning & Tweaking 0 24-05-06 09:21 AM
Wiring help please?? Hogzi SV Talk, Tuning & Tweaking 8 31-03-06 07:18 PM
