Old 05-03-09, 09:52 AM   #1
Alpinestarhero
Default Some things garunteed to make your SV feel better.
Here are some simple maintainence tips to try with your SV if its feeling a bit lag:
1) oil level - if its low, top it up. I did on saturday, and my engine runs alot smoother
2) chain - clean it, lube it, adjust it.
3) clutch - clean it, adjust it, lube it
4) tyre pressures - make sure your rear isnt 31 psi like mine was this morning. I find 34 front and 38 rear with my BT012's feels good
Old 05-03-09, 10:02 AM   #2
Default Re: Some things garunteed to make your SV feel better.
Otherwise known as RTFM
Old 05-03-09, 10:11 AM   #3
Dave20046
Dave20046's Avatar
rubber ...something ..... fluid ...motor?
Old 05-03-09, 10:12 AM   #4
Dave20046
Dave20046's Avatar
What part of your clutch did you lube? The plates lol?
Seriously though, the cable (bits you can get to and poor a bit down the top?), lever and moving bits under the front sprock cover or am I missing a bit?
Old 05-03-09, 10:14 AM   #5
Read The F#cking Manual
Old 05-03-09, 10:14 AM   #6
Spoton.
Old 05-03-09, 10:18 AM   #7
Dave20046
Dave20046's Avatar
Oh yeah you've said that too me before and I got it that time
Thought you were doing the RWPO Rubber, water, power, oil thing or wahtever it is.
Old 05-03-09, 10:20 AM   #8
Alpinestarhero
Yea, those bits.
My SV was feeling pretty crap last week, so saturday had me clean and lube stuff (clutch cable, clutch worm-drive, the spring was lubed). felt much better afterwards. Felt soft before, like I was compressing the worm drive against a block of rubber...horrible, no feeling in the clutch really. Gear changes were pretty poo aswell, so the chain clean and lube helped out alot with that
Old 05-03-09, 10:28 AM   #9
Dave20046
Dave20046's Avatar
Aye once I've ground my mastercylinder to bits in frustration and bought a new one and finished sorting out the brakes I need to pay my clutch some attention.
Old 05-03-09, 10:29 AM   #10
Dave20046
Dave20046's Avatar
Try jacking up your front wheel a*hero and spinning it by hand to see if there is any brake drag. I thought mine were fine but after hearing a knocking noise did this and found the brakes were dragging the disc about. That'll do some good.
Songs That Make You Feel Emotional Lissa Idle Banter 105 20-10-10 11:16 PM
Off work sick? how does your boss make you feel? rowdy Idle Banter 46 12-03-09 09:50 AM
Body position, or how to make things really complicated. metalmonkey Bikes - Talk & Issues 29 15-04-08 12:51 AM
I feel a bit bad ... Blue_SV650S Bikes - Talk & Issues 13 19-12-07 06:55 PM
Make up artist of make up artists... noisie SV Talk, Tuning & Tweaking 0 03-10-07 05:22 PM
