When I bought it it bucked about badly. That's what they do, though, isn't it. Then I adjusted the chain and the throttle cable - big improvement.
Some significant vibration at about 8000 which I assumed I was stuck with. But when I balanced the throttle bodies - hey presto. Still harsh at the front but that's what they are like, isn't it. Replaced the fork oil - you could almost say it's plush. The GSXR600 shock helped that, too. Broke the brake pedal and in fixing it I greased and re-assembled the peg and lever. Much nicer. Today I stripped the front brakes, cleaned the winter corrosion off the pistons and the pins that the pads slide on and greased them. I cannot believe how much feel it has now. Isn't maintenance a good thing! |
Yep maintenance is a brilliant thing, roll on next week for my caliper strip and rebuild!
It certainly is - it's amazing how much difference a small amount of effort and very little money can make.
You often don't even have to do anything special - just make sure everything works like it should and a bike feels great.
What additives / maintenance? | MiniMac | SV Talk, Tuning & Tweaking | 1 | 14-04-08 09:04 AM |
Maintenance? | catchsomesv650 | SV Talk, Tuning & Tweaking | 20 | 17-08-07 10:58 PM |
SV Maintenance | Draper | Bikes - Talk & Issues | 6 | 21-05-07 10:27 PM |
Maintenance tuition. | Spanner Man | SV Talk, Tuning & Tweaking | 12 | 16-03-06 02:35 PM |
My motorcycle maintenance course... | Cloggsy | Idle Banter | 9 | 25-01-06 02:25 PM |
