Old 10-03-09, 05:21 PM   #1
SV400Rob
SV400Rob's Avatar
Default SV400 Exhaust.
Hi, I'm after a sports can for my SV400 but no where lists a can for the 400. Would a 650 can suite the 400?
Cheers Rob
SV400Rob is offline   Reply With Quote
Old 10-03-09, 05:27 PM   #2
sam anon
Default Re: SV400 Exhaust.
I would imagine so, but take no responsibility if it doesn't!
Old 10-03-09, 07:31 PM   #3
As above, I'd be very surprised if it didn't, but the 400 being somewhat unusual I can't imagine many people have tried.
In your position I'd ask someone with a 650 to compare pipes, (ooerr!), look at the relevant positions and dimensions, assuming you discover the diameter of the pipe is the same, I'd be confident it will fit.
Old 11-03-09, 12:10 AM   #4
SV400Rob
SV400Rob's Avatar
If I measured the diameter of the front down pipe on my 400 and then measured the downpipe off a 650, which i have in the shed, would that be good enough to say yeah a 650 can will do?
Old 11-03-09, 12:17 AM   #5
No measure the pipe that goes up into the can!
Old 11-03-09, 12:19 AM   #6
zsv650
borrow one and see.
Old 11-03-09, 12:20 AM   #7
But then you've got to cut the original to try it...
Old 11-03-09, 12:20 AM   #8
zsv650
gotta cut it anyway.
Old 11-03-09, 07:46 AM   #9
Specifically; measure it where the collector will need to be cut, that is the fatter bit of pipe after the two pipes join - the bit under the right footrest that goes into the can.
Downpipe refers to each individual cylinder's bit of pipe before they join together.
Old 11-03-09, 08:38 AM   #10
zadar
pipes are identical
SV400 damonlathe SV Talk, Tuning & Tweaking 3 11-10-06 09:05 AM
SV400 Marshall Idle Banter 8 09-09-06 08:23 PM
WTB; sv400 svracer01 Stuff Wanted 0 31-07-06 09:24 PM
SV400 - SV650 Dimax3 SV Talk, Tuning & Tweaking 1 26-07-05 03:26 PM
SV400? JakeRS SV Talk, Tuning & Tweaking 7 11-04-05 06:02 AM
