Old 13-03-09, 08:42 AM   #1
JamesMio
Default No Speedo, No Lights, No Rev Counter, No Dash.
2000 Curvy
Pretty much everything electrical seems to have gone on the SV - happened last night.
I've now got no speedo, no rev couner, no neutral/oil lights etc, (the only dash light that works is main beam when I flash it).
The heated grips seemed to be playing up last night, I'm wondering if I've popped a fuse somewhere? Is there a main fuse that would take out all of the above in a one'r?
JM
"That **** on the push-bike."
Creatomatic
Old 13-03-09, 08:47 AM   #2
Baph
Default Re: No Speedo, No Lights, No Rev Counter, No Dash...
I have the same issue on my K6. Prime suspect is the connectors behind the headstock, I just haven't got around to sorting it yet.
Old 13-03-09, 09:10 AM   #3
plowsie
Fuse! Mine was faulty and cut out on one one night whilst Chris Numbers was following me. Its the 15 and I think may be marked as signal, but not sure.
Old 13-03-09, 09:13 AM   #4
JamesMio
Brilliant, cheers lads - I'll have a quick ratch about at lunchtime. Daft question (spot the amateur), fuse box is under the main seat isn't it?
Creatomatic
Old 13-03-09, 09:13 AM   #5
Dave20046
Dave20046's Avatar
that was my first thought, yes it's marked as signal - or the one that affected my dash lectrics was.
Old 13-03-09, 09:14 AM   #6
Dave20046
Dave20046's Avatar
Yep under the seat above the battery, crack open the box and swap the fuses (there's usually some spares in with the others), you may need some pliers to get them out if you've got little girl hands.
Old 13-03-09, 09:17 AM   #7
JamesMio
Ok, thanks.
I've got no headlights / indicators either by the way - likely to be the same fault do you think?
Creatomatic
Old 13-03-09, 09:20 AM   #8
Dave20046
Dave20046's Avatar
Ok, thanks.
try the fuse marked lights (I think??)
Infact inspect all the fuses anyway but swap the signal and lights one (if it is called lights) see how you go, may well be knackered wiring up front end though (I hate electrics )
Old 13-03-09, 09:20 AM   #9
Grinch
You also have a fuse on the starter relay, as all the power in the bike goes through there. Its a 30amp and there should be a spare next to it. Its on the right side behind the saddle shutter (the black triangle), though it could also be that the starter relay has broken down as they tend to corrode, in which case your need a new one. As they break down you tend to get intermittent electrics on the bike depending on the circuit load.
Old 13-03-09, 09:24 AM   #10
Dave20046
Dave20046's Avatar
oops doesn't matter
no lights on dash, nadda dizzyblonde SV Talk, Tuning & Tweaking 13 28-09-08 05:16 PM
Dash lights Question Rick-UK SV Talk, Tuning & Tweaking 3 07-12-06 08:59 AM
rec counter water light?/ dash lights BIKER-DENE SV Talk, Tuning & Tweaking 1 14-02-06 06:54 PM
Dash Lights sprocket SV Talk, Tuning & Tweaking 3 01-12-05 01:59 AM
SV 99-02 dash lights sprocket SV Talk, Tuning & Tweaking 5 31-08-05 12:38 PM
