Old 14-03-09, 02:01 PM   #1
Jay12329
Default Cable routing info needed.
I'm in the middle of re-building my '99 sv650 and I cant work out the routing for the throttle, clutch and choke cables. Can someone post some front end photographs?
Life would have been so much easer if I'd taken the bike apart myself.
ta
J
Old 14-03-09, 03:46 PM   #2
SVDragRacer
Default Re: Cable routing info needed!
Damn, i just had the carbs off so i could have got some pics. Oh well. The throttle cables should go through the gap on the right off the head stock (as if you were sat on the bike) through the forks and loop back to the controls. The choke goes through the gap on the left and again, through the forks and loop back to the control. There should be a couple of holding brackets for wires on each side of the head stock, if you want to put the cables through them as that keeps them in place.
Old 14-03-09, 05:10 PM   #3
shelleyamy
I have others if these dont cover what you need, Mike
Old 14-03-09, 06:25 PM   #4
Jay12329
Thank you your a star Just what I needed!
Old 13-05-18, 11:44 AM   #5
netsurfer
Default Re: Cable routing info needed.
For anyone else wanting this, I was searching for this info and unfortunately images above don't work now.
I did however find the info here
netsurfer is offline   Reply With Quote
a59 info needed davepreston Pennine Massive 6 20-04-09 08:39 PM
Info needed Mikeormark SV Talk, Tuning & Tweaking 8 11-09-08 06:27 PM
Wiring Harness,cable and hose routing 21QUEST SV Talk, Tuning & Tweaking 3 19-05-07 04:48 PM
Sidestand switch cable routing. Normski SV Talk, Tuning & Tweaking 4 01-02-07 06:07 PM
info needed pls Wiltshire7 SV Talk, Tuning & Tweaking 9 21-12-04 12:48 AM
