Old 15-03-09, 04:44 PM   #1
pillphil
Default Fairing Mounting Brackets
What's the craic?
I have a fully faired 06 sv650s but the fairing isn't held on with proper brackets. Because of this the entire fairing isn't lined up properly and the the paint is wearing away. Where would I be able to get these?
The brackets I need are the ones the go onto the radiator.
Old 15-03-09, 07:34 PM   #2
Miles
Default Re: Fairing Mounting Brackets
Obvious place would be to try a Suzuki dealer.
Different years have different sized radiators. The fairing on my K4 mounts straight onto the actual rad. I guess you've got a later model that needs a bracket that spaces out an inch or so between the rad and the fairing?
If so I would personally use a combination of a bit of pipe, some washers and a longer bolt.
Have you got the big elbow shaped brackets with the large round washer attachements (where the crash bungs would go)?
Old 15-03-09, 07:45 PM   #3
pillphil
Cheers, I tried a Suzuki dealer but they didn't have any. I had noticed the fairings were off but didn't know why until I saw a newer sv at the dealers.
I was thinking about something similar to what you suggested but didn't know how long it should be. A bit of trial and error I guess.
I don't have the bigger brackets either but I'm planning to put bungs on it anyway.
Old 15-03-09, 08:52 PM   #4
11bSV650
Hey pill.. There is a bike shop local to me(southern indiana) that you can order then from.. I had to get some new ones when I slammed my 06SV650s into the back of a truck! Google S&S Powersports in Clarksville, Indiana. You can get their shop number, give them a call, let them know what you need, they will pull it up and order it.. If you can't get them let me know I have no problem getting them for ya and shipping them to you free of charge. Just promise not to loose them or bust them up!
Old 16-03-09, 10:27 AM   #5
Nobbylad
Nobbylad's Avatar
Phil - are you after the bracket depicted (badly) below?
I can't find them on any of the on-line fiches (Alpha Sports or the place in Indiana)...if you find one somewhere....please let me know 'cos I need one too!
Old 16-03-09, 07:47 PM   #6
Nobbylad
Nobbylad's Avatar
Apparently you have to buy the whole 'accessory kit' from Suzuki, although I have also been told that you'd have to buy the complete fairing. Either way it sounds expensive, what we need is a good old .orger to post some pics and dimensions off theirs and we can make some up!
Old 16-03-09, 08:08 PM   #7
Bluepete
Bluepete's Avatar
I used two bits or metal from B&Q, about 6 inches long, 3/4 inch wide. Bend into U shape, two holes, voila! 50 pence, job done.
Old 17-03-09, 06:14 PM   #8
fubber
No pics but the dimensions for a 2005 radiator are:-
width on all legs = 20mm
short leg of 'U' (radiator side) = 24mm
base of 'U' = 31mm
long leg of 'U' (fairing side) = 31mm
centre of drill holes = 10mm down from top edge of each leg of 'U'
and I think from memory they fit to lower radiator mount?
hope this helps...
Old 17-03-09, 08:33 PM   #9
Nobbylad
Nobbylad's Avatar
Fab...thanks fubber, think that might help!
Does this pic (not to scale) tie in with what you've said?
And goes here....
Old 18-03-09, 10:38 AM   #10
fubber
Thats it exactly.
PS both hole centres are 10mm from top edge.
brackets for lower fairing on curvey maclovin Stuff Wanted 4 16-09-09 04:58 AM
Race Fairing Brackets? 66wilson SV Talk, Tuning & Tweaking 6 11-06-08 09:54 AM
Pointy k5 lowers mounting brackets wanted touch107fm Stuff Wanted 0 19-05-08 08:43 AM
Suzuki lower fairing brackets sv_nutter SV Talk, Tuning & Tweaking 9 19-01-08 11:42 AM
k2 lower fairing brackets erics02 Stuff Wanted 3 11-11-07 12:56 AM
